Hey JH,
I don't know if you are still wanting input since your post is a few weeks old but I am replacing the hg on my 95 Camry 2.2L, 5fse now and saw your post so I thought I would reply.
The chilton manual says to remove the intake manifold and fuel rail before pulling the head, for the life of me I don't know how that is possible considering a few of the intake manifold to head bolts are impossible to reach unless you have real skinny arms capable of bending in unusual ways. Also due to the routing of the engine wiring harness you can't pull the head/intake manifold together without first disconnecting one end of the harness (either disconnect from the ecu and pull it through the firewall and disconnect enough to get past the intake manifold or disconnect the other end starting at the fuse box and battery and working your way back past the intake manifold), I chose the latter (huge PITA) maybe the former would have been easier? Anyways, once the wiring harness is out of the way, pulling the head with the intake manifold still attached was easy. I disconnected the fuel rail when doing the wiring harness.
Hope my experience helps, if you still need it. Let me know if you have any questions.
MTNiner
