2001 Camry wipers parking in UP position - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2012, 05:01 PM   #1 (permalink)
View mbrae5's Photo Gallery
Was just driving my 2001 Camry with 54,000 miles the other day (in the rain), and all of a sudden the wipers started acting weird. The drivers wiper stopped moving, then started again. I turned them off and they parked in the UP position. Same thing happens when I run them intermitantly. It's like they have forgotten where they are supposed to stop. Anyone have any suggestions? Thanks!
mbrae5 is offline   Reply With Quote
Old 01-26-2012, 10:01 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
It's probably the controller located on the wiper motor. You could replace the motor or try to take the one you have apart and see what the problem is.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 01-27-2012, 12:53 AM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Yeah, carefully disassemble it to see what's wrong, but make sure to put things back if still can't make it work because wiper motors are rebuilt and you lose $25 core charge otherwise.
There are two types, ITTA or Denso, so check yours:
http://my.cardone.com/English/club/m...PARTNUM=432004
The Following User Says Thank You to JohnGD For This Useful Post:
ajkalian (02-15-2012)
Old 02-15-2012, 06:57 AM   #4 (permalink)
View Albetime's Photo Gallery
There is a flat arm inside the motor controller that seems to fall off or break. I made one and it worked for a little while then became dislodged. Found a close out wiper motor assy from Rock Auto and that fixed the problem. You can just remove the black cover for the controller and see inside.
Albetime is offline   Reply With Quote
