Are these different colors?
Supposedly Gen 3 uses the silver spring tightened at 0 TDC, and Gen 4 uses the green spring tightened at 45 BTDC. If they're both the same color then I vaguely remember something about 13 coils.
Also, are the coil ends flat (Gen 4) compared to each other or perpendicular (Gen 3)?
Edit: Ok, looks like Gen 3 and Gen 4 are now the same spring. According to this you shouldn't use one with 10 coils, it's supposedly outdated. Toyota TSB EG001-99; January 29, 1999: For 1992-96. Sounds like Gen 3 and Gen 4 are now tensioned the same way at 45 BTDC if the spring is green.
http://www.2carpros.com/questions/to...will-not-start
