spark plug wires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2012, 08:59 AM   #1 (permalink)
View 5thgencamryJ's Photo Gallery
spark plug wires
i'm not a mechanic, trying to install myself. (did 2 so far). There is a clip on the non-spark plug side. whats the easiest way to get it off? with flat screwdriver? Its very tight.
5thgencamryJ is offline   Reply With Quote
Old 01-29-2012, 01:04 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
4 cylinder? yeah, that tiny clip is easiest to gently pry off (by slightly rotating the screw driver blade) with a flat screw driver, just don't break it. that's what I do every time on 5s-fe when unplugging spark plug wires.
Old 01-29-2012, 03:22 PM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
If yer replacing the wires...it shouldn't matter if you break off the old ones...
I just use some plies to crush the old connector and then it comes out. Make sure you are using some dielectric grease to lube up the boots so they don't stick when it comes time to pull them. It also helps seal out the elements to keep the connections from corroding. It only takes the small packet to coat the boots...less than $1.50 from the parts store.
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 01-31-2012, 06:36 PM   #4 (permalink)
double dose camry
View mail2_jb's Photo Gallery
Just replaced my wires with 4 NGK from advanced auto parts ($24 with some online coupon)
I used a flat head screwdriver to pry up the little lock tab on the spark plug wire and pulled up.
2000 Camry 4 Cyl, LE, 99,983 miles
2000 Camry 4 Cyl, LE, 83,486 Miles
mail2_jb is offline   Reply With Quote
Old 01-31-2012, 07:16 PM   #5 (permalink)
View fullofzen's Photo Gallery
3rd Generation
+1
I changed out my wires a few weeks ago and had the worst trouble getting those plastic tabs to disengage -- ended up just wedging a screw driver under the plug wire boots and snapping them. Doesn't really matter if it's an old cable...
1993 Camry LE. 2.2 4cyl, 5S-FE, Auto, 145K
fullofzen is offline   Reply With Quote
Old 01-31-2012, 07:47 PM   #6 (permalink)
BamZipPow's Avatar
Just as an added note on why you need to use the dielectric grease...check out my entry on this thread...with piccies!
Replacing spark plugs (5vzfe)...
Old 02-01-2012, 06:16 PM   #7 (permalink)
double dose camry
shoot, when I changed the wires last week, didn't do this. Gonna get some dielectric grease next week. You said to put the grease on both ends of the wire, confused here. I read somewhere to put the grease only on the white part of the spark plug and shouldn't put anything where the metal is contacting the wire. The other end of the wire is all metal, plugging into the distributor(?), so where to put the grease on that end?
Old 02-01-2012, 06:20 PM   #8 (permalink)
3rd Generation
You should -- unless someone has better advice -- just put some of the grease lining the inside of the spark plug boot. You'll be able to tell how far back is too far.
Anyone disagree?
