About time to do some gaskets - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2012, 08:18 PM   #1 (permalink)
Gameroom cash: $177500
View ShawnTRD's Photo Gallery
Looks like my valve cover gasket is ready to be replaced. What are some of the other common gaskets to replace on a I4 with 100k miles.
MY 1998 Toyota Camry LE
http://www.toyotanation.com/forum/sh...d.php?t=368035
ShawnTRD is offline   Reply With Quote
Old 01-29-2012, 09:11 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Check out the stickied DIY thread on the valve cover gaskets...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 01-30-2012, 07:58 AM   #3 (permalink)
What I'm asking is other then the VC gasket is there other gaskets or seals or o-ring that are know to leak?
Old 01-30-2012, 08:15 AM   #4 (permalink)
View WaxonWaxStillOn's Photo Gallery
Do you have any other leaks/wet spots?
There are a bunch, but probably not something to do unless it's leaking imo. There is the distributor shaft o-ring and the oil cooler o-ring(s?) under the oil filter, and of course the oil pan. Deeper in, when doing the timing belt, there is the crankshaft main seal and camshaft seal, along with the o-ring and seal for the oil pump.
1994 Camry LE
4 cyl 2.2L 5SFE, 180k miles, tan
WaxonWaxStillOn is offline   Reply With Quote
