my coupe, which is a 4cylinder, happens to stall or dies off everytime i take her for a 30 minute drive. After it shuts off, i can start it up again and drive off with it but it'll die off when i come to a stop where i put the car back in neutral and when i give it a little gas, it goes back to normal rpm which is at 900rpm. i just recently have this problem. i did a full tune up on her and it didn't do anything. This is a 94 coupe 4 cylinder 5 speed.
BamZipPow, Check engine light works, but i have no cel, only mods i have are intake and headers, Dont know about the fuel filter, i replace spark plugs, spark plug wires, cap and rotor, igniter, external coil and coolant temp tensor.
richie, i can crank it right back up with no problem, but after driving it for another couple minutes, it dies off again, and i can crank it right back again.
So it has trouble idling? Does it ever "hunt"?... idle RPM surges up & down?
I'm guessing it's the IAC (Idle Air Control) valve; it's carboned up and needs to be cleaned. It's a really common problem. Here are a couple threads showing how to remove/clean it:
I was thinking it might have a bad ignition coil, which often will cause the engine to die when it's warmed up. But the fact it'll restart immediately points more strongly to the IAC valve as the culprit.
stillrunning, it'll run if i give it a little gas, but if i rev it up to 5k rpm, the engine goes back to normal idling.
i did the iac cleaning and still nothing. car still dies. my dad is telling me that my distributor might be bad, but i doubt it. Any other suggestions?
it'll run if i give it a little gas...i did the iac cleaning and still nothing. car still dies.
You may have a defective IAC, or a dropped signal to IAC from a bad connection (inspect and clean with electronic cleaner). If giving it a little gas from the gas pedal keeps it running then it's not bad distributor.
You should also inspect the operation of and clean the EGR. If it is not closing fully then it's a vacuum leak and that will stall the engine at idle as well as give erratic idle. Other vac leaks that may develop when hot will also cause stalling. Check and clean the PCV as well as if it sticks open then engine will stall.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
