Transmission issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2012, 08:56 AM   #1 (permalink)
View cwshugart73's Photo Gallery
Transmission issue
The o/d on my 94 camry xle only works when the outside temp is in the 40's F.
I can drive my car in the afternoon when leaving work or after sitting all day in front of my house and the o/d wont engage. When i drive it to work in the early morning when the weather is cold, the o/d works fine. I changed the trans fluid/filter and everything looked normal under the pan.
Just in case it matters...It also needs an O2 sensor (will change next pay day) per a code scan and it did have a P0401 but it went away on its own.
Any ideas on whats happening with my o/d?
cwshugart73 is offline   Reply With Quote
Old 01-30-2012, 01:21 PM   #2 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Sounds like yer solenoid might be sticking but you didn't mention any codes fer that. Are you sure you have the ATF at the proper level? Do you know how to measure it?
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 01-30-2012, 06:53 PM   #3 (permalink)
Yeah the fluid levels are perfect! Last month i was getting code P1705. I fixed it with a new sensor. Which of the solenoids controls the o/d?
