Removing cruise control (1MZ-FE) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2012, 06:52 PM   #1 (permalink)
AlphaOnion's Avatar
View AlphaOnion's Photo Gallery
Question Removing cruise control (1MZ-FE)
I want to remove the entire cruise control system from my '94 V6 (to save weight and I never use it), so can anyone explain to me how this is done?
1994 Lexus ES300
Clear corners, '96 model rear-end conversion, Weapon-R CAI, OBX muffler, Oracle Halos, custom 2-tone paint, 6000k HID, weight reduction, full LED lighting
AlphaOnion is offline   Reply With Quote
Old 01-30-2012, 11:17 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
1. remove the cruise control box from the engine bay.
2. reroute the throttle cable (that used to go into the box) to the throttle body
3. cut a notch in one of the throttlebody cable holder bolt holes so that it can slide a bit backwards (otherwise your butterfly will always be open and you'll be idling at 4K+)
4. if you're hardcore, remove all related electronic units
HaHa
The Following User Says Thank You to Eye8Pussies For This Useful Post:
AlphaOnion (01-31-2012)
Old 01-31-2012, 02:09 AM   #3 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
You would probably save more weight if you clean out your trunk, glovebox, and oh yeah all the loose change in the ashtray and cup holders. LOL
Pvt-Public is offline   Reply With Quote
Old 01-31-2012, 10:07 AM   #4 (permalink)
AlphaOnion's Avatar
I already did lol. Not only do I never have ANY junk or foreign objects in my car, but I've removed everything I possibly can to save weight without affecting the exterior or interior appearance. So yes, I am pretty hardcore.
- hood and trunk reinforcements
- hood supports
- hood insulation
- complete trunk lining
- swapped spare tire for lighter one
- plastic engine cover
- radiator cover
- rear towing hooks
- skid plate
I'm moving down the list and cruise control is the next unnecessary weight to remove.
1994 Lexus ES300
Old 01-31-2012, 06:43 PM   #5 (permalink)
rusty9's Avatar
Gameroom cash: $441005
View rusty9's Photo Gallery
you should talk to that other nutjob on here that started replacing all those heavy steel 10mm nuts and bolts on his car with nylon ones.
rusty9 is online now   Reply With Quote
Old 01-31-2012, 07:52 PM   #6 (permalink)
I wrench, therefore I am!
Gameroom cash: $214200
View TedL's Photo Gallery
I'm curious to know what do you do to minimize fuel weight. Ride on "E" and refuel every 25 miles?
TedL is offline   Reply With Quote
Old 01-31-2012, 07:54 PM   #7 (permalink)
Gameroom cash: $122650
View 93cr250's Photo Gallery
start removing every body panel and all doors, that should save some weight
1995 Camry LE sedan 4cyl auto, tan 165,000 miles- mine
1996 Camry LE sedan 4cyl auto, white 206,000 miles- dads
93cr250 is offline   Reply With Quote
Old 01-31-2012, 08:04 PM   #8 (permalink)
AlphaOnion's Avatar
Haha calm down guys, I'm not THAT extreme. I'm only removing things that are:
- unnecessary
- won't affect the appearance of the exterior, or the passenger compartment
- won't make the car dangerous, unstable, or undriveable
If it doesn't comply with all the rules above, it stays on. So far I've taken off about 50 pounds worth of miscellaneous things, and you can't even tell without opening the hood or trunk.
1994 Lexus ES300
Old 02-01-2012, 03:34 AM   #9 (permalink)
slpr1mz FTW :-)
slpr1mz's Avatar
View slpr1mz's Photo Gallery
the system is literally 3 lbs. you'll just be better to leave it in. those night where you get tired or are worried about other things starts w/ road... ends w/ something that sounds like bome hahaha
but really, i started to build a track ready NA 1MZ-FE and it was fun but w/ getting tired every now and then and getting speeding out of my head i enjoyed cruising the freeways of so cal low and at 60-65mph.
loves it when i make ppl regret not downshifting ;-)
TRUST YOUR DRIVER RESPECT YOUR MONKEY
http://www.cardomain.com/id/slpr1mz
slpr1mz is offline   Reply With Quote
Old 02-01-2012, 03:36 AM   #10 (permalink)
slpr1mz FTW :-)
slpr1mz's Avatar
oh by the way, the 1mz-fe can go about 30-40 w/ the low fuel light on and taking it easy. i average 17mpg to a tank and when i need to i can get about 24, but then i had a lead foot and didn't like shifting until higher rmps.
Old 02-01-2012, 10:21 AM   #11 (permalink)
TN Pussy Man
pull up your carpet and remove all sound-deadening as well
and then do a tranny swap- you'll save about 150lbs right there
HaHa
Old 02-01-2012, 10:22 AM   #12 (permalink)
AlphaOnion's Avatar
Honestly, I don't take road trips so I don't plan to ever use it. But I'm still wondering if 3 lbs is worth it, since I'll just have to reinstall the whole thing when I sell the car.
1994 Lexus ES300
Old 02-01-2012, 10:27 AM   #13 (permalink)
AlphaOnion's Avatar
Tranny swap? As in switch to 5-speed? I don't know about that... I'm a brand new driver and I really don't feel like learning to drive stick LOL
1994 Lexus ES300
Old 02-01-2012, 03:13 PM   #14 (permalink)
Pvt-Public's Avatar
Yes you are, come on now. 6 ounce tow hook, 8 ounce plastic cover, hood insulation?
And you won't have to replace all the other crap too? What is your rationale for all this. It isn't gas mileage you said you don't take road trips. And if it isn't worth it to take out a 3lb piece how is it worth it to remove a 6 or 8 ounce piece?
Old 02-01-2012, 04:13 PM   #15 (permalink)
Haters Gon Hate ;]
gr91's Avatar
Gameroom cash: $130750
View gr91's Photo Gallery
Remove you're a/c compressor and the a/c lines. Bam about 30lbs! I rarely ever use my a/c! Only when I'm out on a date or when I had my corolla and hadmanual wndows and felt too lazy to even try to roll the windows down! Lol
My current 5sfe has no a/c compressor. I took it off for 2 reasons, the clutch went bad, and it didn't even have any freon or anything, so what's the point?
-1991 Corolla Dx - gone :/
-1992 Toyota Camry LE- Restoration Project-FAILED!
-2008 Honda Civic ex Coupe!
gr91 is offline   Reply With Quote
Tags
1mz-fe, camry, control, cruise, remove
