Yep, chances are good your car's IAC valve is fouled and needs to be cleaned. You can try spraying some throttle body cleaner into the throat of the intake. That sometimes works. Or to be more thorough, you can remove, disassemble, and clean the IAC valve. I'm guessing by your username that you have a '97? In that case, the IAC valve is similar for the V6 & 4 cylinder engines. Here are a couple of threads showing how to do that:
Thread 1.
Thread 2.
