Camry V6 heavier steering than V4 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2012, 08:09 AM   #1 (permalink)
View dk1975's Photo Gallery
We have a V6 Camry and a V4 Camry (same 2001). Steering of the V6 one is much more heavier than the V4. Taken it to the mechanics and all they said was due to the heavier V6 engine, the steering is heavier.
Has any one noticed this? Is it true that a V6 is supposed to have heavier steering than a V4 or just something wrong with the V6?
dk1975 is offline   Reply With Quote
Old 02-01-2012, 11:38 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
No
Yes, and you need a new mechanic.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 02-01-2012, 11:46 AM   #3 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
V4? Toyota's don't make V4s.
Also, the mechanics doesn't know what they're talking about. Just because the engine is bigger doesn't mean the steering is. There's probably something wrong with your whole steering. Check your rack & pinion, there could be a leak. Check the steering knuckles, your control arms, or bushings. Again, find a real mechanic that won't tell you BS like that ever again.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 02-02-2012, 02:56 PM   #4 (permalink)
slpr1mz FTW :-)
slpr1mz's Avatar
View slpr1mz's Photo Gallery
also tires and make sure your steering line isn't leaking. or even if you have power steering fluid in it at all haha
loves it when i make ppl regret not downshifting ;-)
TRUST YOUR DRIVER RESPECT YOUR MONKEY
http://www.cardomain.com/id/slpr1mz
slpr1mz is offline   Reply With Quote
Old 02-04-2012, 04:54 PM   #5 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $294873
View Buurin's Photo Gallery
If that is indeed the case his steering would be very whiny. Been there, fixed that.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
Old 02-04-2012, 05:05 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
I actually think that 1mz-fe V6's power steering DOES feel heavier than 5s-fe's ... I have both models to compare between and that is the case here.
The only differences are:
a) ps belt tension at lower spec limit on V6 while at higher spec limit on 5s-fe
b) V6 using a Mobil1 ATF in PS system while 5s-fe is using Castrol IMV ATF over there
it could be that Mobil1 ATF fluid is causing this actually as V6's transmission (running same fluid) is also "harder" now than 5s-fe's using Castrol IMV ATF. in SPrin gI will switch V6 to Castrol and compare. maybe I will retension new PS belt on V6 too, so I have more direct comparison.
Old 02-04-2012, 05:58 PM   #7 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
Just a heads up, the P/S system calls for Dex III fluid
This whole "V6 steering is heavier because is it's a V6" thing is BS. I would get the system checked out
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 02-04-2012, 06:43 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
and Mobil1 ATF is not a DEX-III compatible type?
... and Castrol IMV ATF is?
... c'mon, you know better than that
there is nothing to check out in the system, all looks normal, no leaks. only real difference is the ATF used between the v6 and i4 I own.
fact is that V6 IS heavier than i4 while power steering system between the two seems the same to me (except for a fluid type difference I have).
Old 02-04-2012, 06:46 PM   #9 (permalink)
TN's Mad Chemist
I wasn't saying get your car checked out, I was talking to the OP I realized for some reason when I read your post ATF registered as P/S fluid in my mind for some reason Mechanically, the steering is the same, I don't see why one should feel heavier than the other. Besides, I've driven the 5S-Fe, and the steering feels identical to mine
1997 Acura RL-Gone
Old 02-04-2012, 06:53 PM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
LOL gotcha
anyways, my 5s-fe steering after a full flush, belt change, and switch to Castrol IMV ATF feels VERY light when compared to V6's (after same procedures, only Mobil1 ATF used).
not sure what up, but I have an impression that you don't know how light (almost "one finger light") the well maintained 5s-fe steering system can be no offense. so far I failed to have such "light" ps on v6, will know more after I switch the fluid to Castrol and maybe retension the belt with a real pry bar.
Old 02-04-2012, 06:57 PM   #11 (permalink)
TN's Mad Chemist
LOL gotcha
My steering is light, I can pull out of a parking spot using one finger to turn the wheel
1997 Acura RL-Gone
Old 02-04-2012, 07:03 PM   #12 (permalink)
抵抗は無駄です
fenixus's Avatar
hmmm ... I will get back to it once I switch the fluid to Castrol. as of now I would break my finger if I tried that
Old 02-04-2012, 08:30 PM   #13 (permalink)
セクシーの定義
Gameroom cash: $117610
View Jimnist's Photo Gallery
How so? There's more mass over the front wheels with the v6 compared to the i4. It's not heavy like there's no power assistance, but requires just a bit more force to turn as opposed to one finger.
From my experience with the 2 v6's and 2 i4's, the 4 cyl's steering is definitely lighter than the v6 counterpart. I have also experienced power assistance fail on both cars and can tell you, again, it was easier to steer the 4 cyl than the v6.
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline   Reply With Quote
The Following 2 Users Say Thank You to Jimnist For This Useful Post:
dk1975 (02-07-2012), fenixus (02-04-2012)
