Yeah, it could be plugs & wires if they haven't been changed in a long time. What model year & engine do you have?... any recent maintenance done?... more info helps. Plug change interval varies a bit depending on which engine, but 100k miles at the most (160,000 km).
Also could be the IACV (Idle Air Control Valve) is fouled and needs to be cleaned. It's a common problem. I can steer you to DIY threads to clean it after knowing which motor you've got.
Also could be air/vacuum leaks in the intake tract downstream from the MAP/MAF sensor.
