Help Needed in Re-installing Distributor 96 Camry 5SFE 4 Cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2012, 10:23 PM   #1 (permalink)
View DOOSAM's Photo Gallery
Hi,
I removed distributor to check O ring but unable to reinstall it as distributor will not slide in, i have not changed the O ring. I have oiled the O ring and opening and I am putting it back exacltly the way it came out with the same orientation.
What I am doing wrong ? Is there a trick to reinstallation? Any tips ?
Thank you in advance, appreciate your help.
Sam
DOOSAM is offline   Reply With Quote
Old 02-02-2012, 06:06 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
You'll have to turn the part that fits into the Camshaft until it plops in place.
If its 180 degrees out, it will not be flush with the head/valve cover (it will have 1/4 to 1/2 inch gap)
Old 02-04-2012, 09:14 PM   #3 (permalink)
Thumbs up Help Needed in Re-installing Distributor 96 Camry 5SFE 4 Cyl
Mister_Perkins, thank you your suggestion worked great - it was 180 degress out.
Sam
Old 02-04-2012, 09:15 PM   #4 (permalink)
Glad ya figured the problem out!
Old 02-05-2012, 10:40 AM   #5 (permalink)
View djb2's Photo Gallery
For other people reading this: the distributor drive has a slot that is slightly off-center. If you don't look carefully you might think it's symmetrical and install the rotor a half turn off.
djb2 is offline   Reply With Quote
