Engine washing the camry... ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2012, 07:29 PM   #1 (permalink)
Toyota 4 Life
TravisAe86's Avatar
View TravisAe86's Photo Gallery
I've brought all the needed stuff to clean my engine and give it a nice wash to make it clean and shiny... but I kno theres certain parts you have to cover before you let the water hit... any one kno all the parts
TravisAe86 is offline   Reply With Quote
Old 02-02-2012, 07:50 PM   #2 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
I don't cover anything when I take mine to the car wash. Never had a problem. Just don't directly spray the exhaust manifold or the alternator. The only thing I found is a little bit of rust in the spark plug tubes, probably because I got water in there, so I'm a bit careful now not to point the spray directly at the coil packs.
First I hit it with the engine de-greaser, then get on the ground, towel under the knee, and spray the undercarriage and brakes with de-greaser. The soap everything, and then rinse. Pay particular attention to the steering rack, from both sides, and while you are back there get the back of the valve cover if you have a 6-cyl. Take the hubcaps off, blast the brakes and get all the dust off the rims.
I do it most every oil change since Toyota's lousy design placement of the oil filter almost always results in me making a mess. So it's off to the car wash I go.
Dry everything off, and then pretty it all up with a little Armour-All. When you are done it should look like this.
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is online now   Reply With Quote
Old 02-02-2012, 08:13 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
^ what he says, I don't cover anything either when pressure washing.
Old 02-02-2012, 08:20 PM   #4 (permalink)
Toyota 4 Life
TravisAe86's Avatar
First thanks for the quick reply :-)
Do you jack up the car when you spray underneath it ? and I've never seen anyone soap their engine. How long do you let the de-greaser sit for before you wash it off
btw your engine looks brand new
Old 02-02-2012, 08:20 PM   #5 (permalink)
Toyota 4 Life
TravisAe86's Avatar
You guys are brave.... shooting water at the engine like that and not one of you cover anything lol
Old 02-02-2012, 09:09 PM   #6 (permalink)
It's not.
That one had 180,000 miles on it when the pic was taken.
Old 02-02-2012, 09:53 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
if engine is not red hot than it's OK. warm is fine. just don't shoot the water onto spark plugs boots or wires or ignition coils, avoid hitting the alternator, battery and distributor on gen3 and you will be fine.
I usually spray everything with a foamy degreaser spray and let it sit for 5 mins and then do a pressure wash and wipe everything up roughly with a cloth later. never a problem.
water mist or sprinkle getting into or onto mentioned above parts is insignificant. it happens every time you are driving in a rain, right?
Old 02-03-2012, 07:48 PM   #8 (permalink)
Toyota 4 Life
TravisAe86's Avatar
so I washed my engine and kind of F'ed it up...
After I applied all the cleaing products I watered down the engine and it seemed the spark plug wires were not all the way down and water got inside where the spark plugs are.... car didnt start for about 2 hours no matter what i tired. I plug apart everything and let them air dry and took a rag and wiped out any water inside the spark plug camber and disconnected all plugs and dry them off. Then finally the car chocked back to life
Old 02-04-2012, 08:02 AM   #9 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
Good info I need to clean my engine bay on the coupe. It is dirty as hell
Sent from my LG-MS690 using AutoGuide.Com Free
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 02-04-2012, 06:11 PM   #10 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
I always wrap any obvious wiring in aluminum foil: Coolant temp sensors, O2 sensors, grounds, etc... I started doing that after watching a pro detailer do it
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 02-04-2012, 06:18 PM   #11 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I wont pressure wash my engine like that. Too many things could go wrong. I would cover everything that could go bad before pressure washing if I were you
Old 02-04-2012, 06:20 PM   #12 (permalink)
TN's Mad Chemist
Agreed! I should also add I never pressure wash, I wash. My pressure washer NEVER goes anywhere NEAR my paint or engine. The only thing it sees are the carpets.
1997 Acura RL-Gone
Old 02-04-2012, 06:53 PM   #13 (permalink)
I pressure wash the undercarriage of the car
