1 or 2 Coolant Temp Sensors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2012, 07:05 AM   #1 (permalink)
Gameroom cash: $177500
View ShawnTRD's Photo Gallery
I remember on another Toyota forum I was on for Land Cruisers they said Toyota has two different Coolant Temp Sensors. On for the gauge and one for the computer. Is that true with the camry's? The report on the LC Forum was if you started getting bad MPG it could be the Coolant Temp Sensors to the computer making the motor run rich. Will I went from 30 mpg summer, to 27 mpg winter to now 25 mpg in the last 3 or 4 weeks. The only other thing I did is replace my old purolator air filter with a new wix air filter.
MY 1998 Toyota Camry LE
http://www.toyotanation.com/forum/sh...d.php?t=368035
ShawnTRD is offline   Reply With Quote
Old 02-04-2012, 01:15 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
on the 92 to 96 camry they have one next to the head(gauge) and another one on the radiator (ecu)
Old 02-04-2012, 01:39 PM   #3 (permalink)
What about 98?
Old 02-04-2012, 02:47 PM   #4 (permalink)
More than likely it does.
Old 02-04-2012, 03:23 PM   #5 (permalink)
Are they the same part # just in different locations?
Old 02-04-2012, 03:24 PM   #6 (permalink)
no, they are two different part numbers
Old 02-05-2012, 12:31 AM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
98 (4cyl) Camry LE (AT, US made) has 3 ECT "sensors"
a) ECT sensor for E.F.I. (ECU), mine has a green plug and there are 2 wires coming out of it, it sits on the driver side of engine water outlet
b) ECT sender (for dash gauge), has a grey plug, only 1 wire and it sits right next to the above one
c) ECT switch for fans, sitting in bottom of radiator, passenger side I think it was
Part number for ECT for EFI on 98 camry LE 4cyl is: 89422‑20010
and a new copper gasket for it is: 90430‑12005
torque s 14ft-lbs and a 19mm deep wall socket fits over the plug.
Old 02-05-2012, 07:24 AM   #8 (permalink)
Thank you very much.. Very very helpful
Old 02-05-2012, 07:29 AM   #9 (permalink)
I wrench, therefore I am!
Gameroom cash: $214200
View TedL's Photo Gallery
Winter mileage will be lower. Due to temp, and due to ethanol added. And then people use remote starters, giving zero mpg. Or just idle more to warm up the car.
TedL is offline   Reply With Quote
Old 02-05-2012, 07:42 AM   #10 (permalink)
Yes I know but without changing any other habits I've lost another 2 mpg in the winter. On top of the normal 3 mpg I normally lose.
Old 02-05-2012, 07:58 AM   #11 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
You can test the sensors with heating water, a thermometer and ohm meter against specs. There should be a graph with temp versus resistance readings.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 02-05-2012, 01:52 PM   #12 (permalink)
抵抗は無駄です
fenixus's Avatar
yup, guys above are right. here is the graph all camry based cars follow on ECT "sensors" (all of them):
around 200-230 ohm at fully warmed idle (or right after shut down) is OK and that's where it's supposed to sit. however to be honest you may need to remove that sensor and test it out throughout a full range while in a hot bath. it may have dead spots (mine did, both on V6 and i4).
my Winter MPG always suck big times, both because of longer warm up and more accessories on (lights, heating, sometimes wipers, etc.) and then the darned ethanol additive (10% I think it is). on top of that I travel less further (I get lazy in Winter) and most of driving is a bad type of short distance city driving and around here traffic, hills and stop lights/signs are a real MPG killer.
Old 03-23-2012, 06:15 PM   #13 (permalink)
Hoping I can spend $15 or $25 vs $65+ that the dealer wants so.... Does any of the 3 that www.napaonline.com sells match Toyotas?
