Power steering stop leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2012, 07:49 PM   #1 (permalink)
v6camrydriver's Avatar
View v6camrydriver's Photo Gallery
Does anyone have any experience using either Nulon or Prestone Power steering fluid with stop leak and would you recommend it?
My car has a slow (1/4 of a cup every 6 months) fluid leak out of one of the steering rack ends and looking for a fix that doesn't involve overhauling the rack.
v6camrydriver is offline   Reply With Quote
Old 02-06-2012, 07:59 PM   #2 (permalink)
View bolink654's Photo Gallery
I had a similar leak. Tried the prestone -did nothing. Tried the Lucas, that stopped it for about a year, now the leak is back and Lucas does nothing for it. Will put a new rack in someday.
82 Toyota Pickup, 22r, 5spd 4wd, Detroit locker, Warn 8274
1998 Toyota Camry - 5S-FE, Auto - 205k
82 Toyota pickup - 20r, 5spd, 4wd - SOLD
bolink654 is offline   Reply With Quote
The Following User Says Thank You to bolink654 For This Useful Post:
v6camrydriver (02-06-2012)
Old 02-06-2012, 09:01 PM   #3 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
1/4 cup every 6 months = suck everything out of the reservoir and refill with lucas. Problem solved.
carsrus is offline   Reply With Quote
The Following User Says Thank You to carsrus For This Useful Post:
Old 02-11-2012, 10:50 PM   #4 (permalink)
Here goes...
Well yesterday I replaced the rack boot that had popped due to the fluid build up inside it, cleaned up the mess it had caused and fed through most of a bottle of some stop-leak by removing and refilling the reservoir and running the system each time.
Time will tell if the stop leak works but hopefully this will pass it's warrant in the meantime (once I get some new tires!!).
Cheers for your advice.
Old 02-11-2012, 11:21 PM   #5 (permalink)
Oil Nerd
zyxelenator's Avatar
View zyxelenator's Photo Gallery
Lucas what? Sorry but most lucas products are pos.
Sent from my SGH-T679 using AutoGuide.com App
99 Camry V6.
5 speed M/T
149k miles.
zyxelenator is offline   Reply With Quote
Old 02-12-2012, 12:58 PM   #6 (permalink)
Prestone, simply because they didn't have any Lucas, the Nulon stuff wasn't in the right size and I've used other Prestone stuff before and it's been ok.
