Question about changing brake pads on 92 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-07-2012, 12:48 AM   #1 (permalink)
Toyota 4 Life
TravisAe86's Avatar
View TravisAe86's Photo Gallery
Question Question about changing brake pads on 92
I am able to get to my pads and know how to changes them and they are worn down to almost nothing ( damn I drive hard ). I know theres a tool you use to clamp onto the piston where you twist it and it pushes the piston back in to make room for the thicker pads.
I dont have this tool what else can I use? Can I push it in by force or knock it in ?
TravisAe86 is offline   Reply With Quote
Old 02-07-2012, 01:00 AM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
I use a medium sized 4-5" C-clamp with a worn brake pad between the clamp and piston to prevent damage. (it helps with dual piston too.) Then crack/turn the handle slowly to push the piston back. It's best to open the bleeder screw too to avoid overflowing the master cylinder with brake fluid and makes the work easier.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 02-07-2012, 01:18 AM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Yeah, a C-clamp or a bar clamp works if you don't have a caliper tool. Just be careful of the brake hose if you use a large clamp and try to push it back with the caliper in place.
http://www.harborfreight.com/12-inch...amp-96214.html
http://www.harborfreight.com/18-piec...kit-97143.html
Old 02-07-2012, 07:47 AM   #4 (permalink)
Gameroom cash: $123900
View dave1811's Photo Gallery
Using a disc spreader like this one is a piece of cake. It is very cheap (Around $9 or so) and works real well. Use one of your old pads against the cylinder and just compress it in nice and slow. Piece of cake!
99 Camry (141k miles-At the graveyard now!)
99 Camry (161k miles)
02 Sienna
dave1811 is offline   Reply With Quote
Old 02-07-2012, 08:14 AM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Usually I just use my thumbs if the pistons are free enough. If not, I use a C-clamp like others mentioned.
BMR
BMR is offline   Reply With Quote
