So the starter just makes a clicking noise?... it doesn't turn the engine over? That sounds like the battery is low on charge. Either the battery is bad, or the alternator is failing to charge it properly. The only way to know is to get them both tested. Most auto parts stores can test both. If you can't get the car to them, you'll have to remove them (the battery and the alternator) and bring them in.
