i have a 97 Camry that keeps on breaking wheels studs - Toyota Nation Forum : Toyota Car and Truck Forums
3rd & 4th Generation (19921996 & 19972001) Toyota Camry Discussion for years: 1992-1996 & 1997-2001 Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 9 Old 03-06-2012, 09:54 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
my camry has broken three wheel studs and the lug nuts keep coming out is there any good aftermarket wheel studs that are better then then oem ones
m7w7j7 is offline
post #2 of 9 Old 03-06-2012, 11:01 AM
SoCalChino's Avatar
Quoted: 0 Post(s)
There's nothing wrong with the OEM studs. The OEM ones are probably the best because they don't use a cheaper metal. The problem is that someone is over torqueing them. I believe that they should be torqued to 85ftlbs but alot of shops just hit it hard with an impact wrench.
SoCalChino is offline
post #3 of 9 Old 03-06-2012, 11:29 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Well now I don't know how to get rid of the wheel stud that I have broken off right now the volute is spinning in the hub and the Alfred nut broke off and because I have aftermatket rims there is a very narrow hole where the lug nu
t is so I can't get it off
m7w7j7 is offline
post #4 of 9 Old 03-06-2012, 11:35 AM
SoCalChino's Avatar
Quoted: 0 Post(s)
I have no idea what you just said.
The Following User Says Thank You to SoCalChino For This Useful Post:
SirThomas88 (03-06-2012)
post #5 of 9 Old 03-06-2012, 12:08 PM
BMR
Deputy of Mayberry
BMR's Avatar
Quoted: 557 Post(s)
I suspect they mean the lug nut is stuck, and the lug bolt's spline is spinning in the hub.
Can you get to the backside and grind the head off the lug bolt? I'm not sure that's even possible.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 25k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 346k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is online now
post #6 of 9 Old 03-06-2012, 12:24 PM
nitronate33's Avatar
Quoted: 38 Post(s)
sounds like it may be the wheels that are the problem. if the studs are breaking and you have tolerance issues with the wheel hole size/alignment, the wheel could be putting pressure at an angle on the studs, weakening them and eventually snapping them. i can't imagine you would be able to fit wheels with an incorrect 5 lug wheel pattern, but maybe it is possible.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline
post #7 of 9 Old 03-06-2012, 01:35 PM
Quoted: 1 Post(s)
I've had to replace wheel studs on my Camry. It's not too bad. You just gotta take off the wheel, and tap out the stud and pull it out from behind the rotor. Sometimes you have to rotate the wheel hub a bit to get more clearance between the dust plate and the rotor. Then wiggle a new one in from the back. Having small hands helps.
I had to replace two. First one was because I hadn't tightened the lug nuts well enough after changing my brake pads. The second one probably broke because it had been already damaged from when the first one broke.
SirThomas88 is offline
post #8 of 9 Old 03-06-2012, 02:34 PM
Quoted: 2 Post(s)
iTrader Score: 19 reviews
Are you sure you have the proper seat angle on the lug nuts to your rims?
This can create those problems...
FOR SALE:|| Gen 3 & Gen 4 Performance Part-out!
MR2: 436whp-354lb/tq!!
RichieRichJP is offline
post #9 of 9 Old 03-06-2012, 04:19 PM
Senior TN Member
Quoted: 0 Post(s)
I think this. A PO of my camry, must have lost a couple of the lug nuts to mine. The ones they replaced them with had a different angle than the rim and the originals. They did fine for awhile, then one day while removing them, they would loosen a couple turns, then stop... only thing to do was wrench em off and break the lugs. All 3 of the unmatched lug nuts did this.
1995 Chevrolet 1/2ton ext cab 4x4 6.5l Turbo Diesel
1998 Toyota Camry 5SFE Auto
2002 Chevrolet Impala
1997 Nissan Pathfinder 4x4
bolink654 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > 3rd & 4th Generation (19921996 & 19972001)
User Tag List
Linear Mode Linear Mode
Back
