2001 Camry Brake pedal goes to floor. Normal? - Toyota Nation Forum : Toyota Car and Truck Forums
3rd & 4th Generation (19921996 & 19972001) Toyota Camry Discussion for years: 1992-1996 & 1997-2001 Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 14 Old 09-08-2012, 12:47 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
I just got a 2001 Camry ce and I took it to a safety test and it failed.
Reason: brake pedal to low and E-brake to loose. So I took it to mechanic to get it fixed. They said brakes are fine so they bled the brakes, adjusted the E-brake and checked brake pedal and found nothing wrong with it. So I took it back for a safety test and FAILED again. Reason: low brake pedal. So I asked them to show me because it brakes fine as soon as I brake. He pressed brake pedal almost all the way down, turned the ignition on while still pressing firmly on brake pedal and when he did that the brake pedal sunk even lower. He then said " you see that is not normal". "At high speed if you need to brake hard, you may not have enough distance to stop" I then replied it stops fine.
Is this normal on camry's? Any info is appreciated.
Note :I also have ABS
fabii is offline
post #2 of 14 Old 09-08-2012, 01:14 PM
イリジウム
Quoted: 175 Post(s)
Isn't it great that you have that kind of safety inspection? It keeps you and others on the road safe.
But no, a low pedal is NOT normal. You will NOT have the necessary reserve with a low pedal. The last brake shop is probably not "good enough".
Do you feel brake action almost immediately when you step on the pedal? Or do you feel it start to act when 1/2 way down?
Assuming the shop properly adjusted the brakes (another cause of low pedals), if the brake action happens almost immediately (even if weak) then double check for air in the system (you probably need the dealer to activate the ABS). If the latter you may need a new master cylinder.
I'd take it in to the dealer and have them go over it while asking them to purge the ABS system and flush the brake fluid again. In the US it's less than $100 USD.
JohnGD is offline
post #3 of 14 Old 09-08-2012, 02:36 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Thank you for the quick reply.
I would say 1/2 way down.
fabii is offline
post #4 of 14 Old 09-08-2012, 03:28 PM
Dave's
Quoted: 26 Post(s)
I respectfully have to submit a different opinion. I happen to own an '01 Camry as well as an '04. They do the same thing. I even changed the master cylinder on the '01. What I'm told is that it's part of the ABS programming or whatever. Basically once the car is stopped as sensed by the wheel sensors then the brake pedal can be pushed down nearly to the floor because the ABS prevents overloading of system pressure. Guess it bypasses any extra fluid pressure beyond what's needed to keep the car from moving. This isn't meant to be a scientific or accurate explanation of what's going on but just an uncomplicated way to explain what's happening. Now, perhaps all of this is incorrect and several techs and mechanics were all mistaken but I can tell you the car is still driving and stopping fine over a year after changing the master cylinder and it still goes down very close to the floor after coming to a complete stop. Note that on mine, the pedal DOESN'T go down that far until AFTER the car is totally stopped. Only then does the pedal begin sinking to the floor if pressed hard enough.
Dave's is offline
post #5 of 14 Old 09-08-2012, 03:31 PM
Quoted: 0 Post(s)
If this has drum brakes on the rear, ensure the shoes are adjusted out.
There is a star wheel for this.
Your brake pedal should be firm from the initial tap.
Neutral_Site is offline
post #6 of 14 Old 09-08-2012, 03:37 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Dave where did you find out about the abs kicking inandallowing the pedal tomive lower even further
fabii is offline
post #7 of 14 Old 09-08-2012, 04:05 PM
TC01's Avatar
Quoted: 11 Post(s)
USA
I had the same problem with my 01. I have rear drums. I adjusted them by turning the star screw inside and now the brakes are fine. They don't even go half way to the floor. They have a solid feel. Try doing this if you have rear drums. This also helped the ebrake.
1996 Camry LE - 6 Cyl 1MZ-FE 177,000
2001 Camry LE - 4 Cyl 5S-FE 182,000
Both still going strong!
TC01 is offline
post #8 of 14 Old 09-08-2012, 04:48 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
where isit located exactly?
fabii is offline
post #9 of 14 Old 09-08-2012, 04:50 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
wheres the star screw located exact;y?
can this be done without mounting the car?
a jack good enough?
fabii is offline
post #10 of 14 Old 09-08-2012, 06:32 PM
1998 Camry LE
Quoted: 0 Post(s)
I agree with Dave. The brake pedal on my 1998 Camry travels lower when I start the engine and when sitting for a little while at a stoplight; my Haynes repair manual says this is normal for 97-01 Camrys. I did have a problem once where the pedal would travel so low that the brakes would give out and the car would start rolling forward while I was sitting at a stoplight; it turned out to be an internal leak in the master cylinder. (It was not leaking fluid anywhere I could see; my local mechanic made this diagnosis.) After replacing the MC, the pedal still travels lower when starting the engine or sitting at a light, but it does not bottom out like it did before. That's my $0.02; I hope it helps.
1998 Camry 5S-FE (2.2L 4 cyl.) 89,000 miles (about 28 MPG)
2002 GMC Yukon XL 2500 4X4 6.0L Vortec V8 - 189K miles (15 MPG, woohoo!)
Joelwee is offline
post #11 of 14 Old 09-08-2012, 10:30 PM
Dave's
Quoted: 26 Post(s)
My wife complained about the brake pedal going down too far. First thing I did was replace and adjust the rear shoes as they were getting worn down. It bothered me how far the pedal sank with the car stopped so I took it to a mechanic friend to help bench bleed the new master cylinder and flush the system. It really didn't make a difference so he called a Toyota tech friend who asked around the shop to confirm that was the design. We also checked some other cars including a couple of Honda's. All with ABS and most did the same thing. Some took more pressure than my Camry but they still went down with enough force. Older cars without ABS don't do this, you just put a whole lot of pressure on all of the seals, hoses, etc.
I didn't have him press the tech for a detailed explanation of exactly how the ABS does this. He just said it was designed that way to keep the system from being over-pressurized.
Dave's is offline
post #12 of 14 Old 09-09-2012, 12:09 AM
Senior TN Member
Quoted: 2 Post(s)
Since its a CE, I'm assuming rear drums.
Power assist(vacuum) will cause the pedal to drop when you start the car. That same assist will cause the pedal to react when something as simple as the A/C cycles. Its no big deal.
If the inspection shop has an issue, they need to put it in writing with the "measurements" as why you're failing and what "measurement" is required. They can't just say, "the pedal sank". That is what power(vacuum) assisted brakes do by making it easier to press the pedal. Dumb owners drive with a death grip on the brake pedal. Once stopped, how much pressure do you really need to keep from rolling forward?
As always, if you have drum brakes, you need to ADJUST THEM. Too much slack in the shoe to drum clearance will sink a pedal quick. Neutral-Site hit the nail on the head.
If you have any air in the lines, you need to bleed. With ABS, you either need to trigger ABS while bleeding, or bleed then test ride triggering ABS and bleeding again after test ride. Bleed your brakes.
Incorrectly adjusting E-brakes can cause preload on your drum brakes, which will increase wear on the brakes, and cause more temperature variances(pedal feels different when warm or cold out). I find that most mechanics will crank on the e-brake slack adjuster to make up for 'other brake issues', like the simple shoe:drum adjustment mentioned by Neutral-Site.
If you can't stop your car, you have a brake problem. If you can't trigger the ABS on dry pavement, you have a brake problem. If your pedal is to the floor and you begin to role forward, you have a brake problem. Everything else is bleed and adjust!
deadrx7conv is offline
post #13 of 14 Old 10-27-2016, 09:07 PM
TN User
PhilR's Avatar
Quoted: 0 Post(s)
I know this is an old thread but I have a similar problem with my Japan-built 2001 Camry CE V6 with 4 wheel disc brakes, ABS but no traction control. Note that mine is also a Canadian car... (I know that the 2001 CE model wasn't available with the V6 or disc brakes in the US, but here we couldn't get the V6 and disc brakes in the LE model).
I replaced the front passenger side caliper last year and I didn't block the brake hose when I removed it. When I reinstalled the new one, air has gotten in the master cylinder and I didn't succeed at removing the air in the system. I thought there must have been air trapped in the ABS system but I had no idea how to bleed that. I've been driving the car like that for a year and a half, the brakes work and the ABS too but the pedal is still low, very low. I tried to bleed the brakes again and it didn't improve the brake pedal height.
So this week, when I had the car on the lift for another repair, I decided to try to bleed the brakes for a third time, still didn't work, tried to bleed the master cylinder, no success, tried to bleed the brake lines again, no improvement. I didn't find anything else to do, no bleeder elsewhere on the brake system or on the ABS module.
So I ordered a new master cylinder, replaced it and still have the exact same problem. What am I missing?
Phil
1990 Toyota Xtracab 4x4 22R-E 1993 Toyota Xtracab 4x4 SR5 V6 1965 Buick Wildcat 1967 Buick Riviera GS 1975 Buick Electra Limited
PhilR is offline
post #14 of 14 Old 10-27-2016, 09:55 PM
Sr. Member (アンソニー ムクゴーアン)
mcgowaw's Avatar
Quoted: 777 Post(s)
my 94 camry and 01 sienna don't do this but my 06 camry does. i got new pads/shoes and no air in the system so i wondered if my m/c and/or booster was giving up because AFTER i stop, i can press the pedal further down. maybe not to the floor but definitely farther. glad this post came up. now i won't worry about that as it seems it was a feature added sometime around the turn of the millenium.
tony
1994 Camry, V6 XLE 3.0, 1MZ-FE, A541E (4-speed)
2001 Sienna, V6 LE 3.0, 1MZ-FE, A541E (4-speed)
2006 Camry, I4 LE 2.4, 2AZ-FE, U250E (5-speed)
mcgowaw is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > 3rd & 4th Generation (19921996 & 19972001)
User Tag List
Linear Mode Linear Mode
Back
