Rear brakes thumping/wobble noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2012, 11:11 AM   #1 (permalink)
View JJT211's Photo Gallery
My rear brakes make a thumping/wobble noise when medium/hard pressure is applied. In the beginning of drjve with light pressure i dont get any noise. I tried replacing my brake pads and no fix. Thinking maybe rotors next but dknt want to keep throwing parts at it for no reason.
Any ideas?
JJT211 is offline   Reply With Quote
Old 11-20-2012, 11:33 AM   #2 (permalink)
View tkennedy's Photo Gallery
I would suggest havin rotors turned before replacin if poss its cheaper
Sent from my SPH-D710 using AutoGuide.Com Free App
tkennedy is offline   Reply With Quote
Old 11-21-2012, 06:25 AM   #3 (permalink)
Im actually pretty confident its not the Rotors or pins now tha I've had a good luck at the brakes already.
Question: My dad was driving it and said he had bottomed out and banged the muffler and exhaust which dislodged them from each other. He said not too long afterwards is when he began to hear the clicking/wobbling noise from the rear brakes. We had another friend suggest the U-Joint may be bent/broken and it coming in to contact when car's weight is being going forward in one direction while slowing down.
Any other ideas....Ill be looking into it later this evening
Old 11-21-2012, 09:28 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $714503
View BMR's Photo Gallery
There are no U-joints in the rear. Closest thing to a U-joint on a Camry are the CV joints in the front axles.
The parking brakes are integrated into the rear rotors; little drum brakes in the rotor hub, on the back side. Those might be needing adjustment. Try applying the parking brake lightly while moving and see if you hear any noise.
It's really hard to diagnose noises without hearing them. Is it a rubbery thumping?... or more of a metallic sound?
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, now at 344k
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 280k
2001 Yamaha FZ1, Ivan's jet kit, resprung, Ohlins rear shock, Race Tech cartridge emulators in forks, 47k miles
BMR is offline   Reply With Quote
Old 11-25-2012, 10:34 PM   #5 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $153595
i had a similar sound exist from bad lateral control arm bushings. take the weight off each back wheel, grab it at 3 and 9 o'clock and see if there is any movement.
