can this cause a gas smell? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2012, 08:58 PM   #16 (permalink)
Senior TN Member
Gameroom cash: $277405
View 93celicaconv's Photo Gallery
Originally Posted by Perkins View Post
just go get a TVV from Toyota. They arent that expensive , are they? the TVV gets brittle over time. Thats why yours broke anyways. Might as well get a new one that will last 100,000 miles or more
This question was already answered by guapoman2000. If you would have opened his link, you would see this part cost $63 at Advance Auto Parts. At a Toyota dealer, probably 2x that. Aren't that expensive? I guess the one needing to obtain it would have to make that judgment.
http://shop.advanceautoparts.com/buy...149-_-10711125
93celicaconv is offline   Reply With Quote
The Following User Says Thank You to 93celicaconv For This Useful Post:
guapoman2000 (12-09-2012)
Old 01-17-2013, 01:39 AM   #17 (permalink)
View genso's Photo Gallery
can a bad evap system cause hesitation and stall problems?
genso is offline   Reply With Quote
Old 01-17-2013, 06:42 AM   #18 (permalink)
Senior TN Member
It depends upon if the engine is MAF or MAP. But because your question is general, the general response would be "Yes it can."
Old 01-17-2013, 02:11 PM   #19 (permalink)
It is a 1995 camry 2.2 and it doesn't have maf but does have a map sensor.
Old 01-17-2013, 04:36 PM   #20 (permalink)
Senior TN Member
For MAP engines, you can either get too much air (major EVAP leak) or no fuel fumes (clogged or malfunctioning vacuum switching valves). In either case, it should not cause hesitations or stalling. Too much air will cause an increase in idle RPM though.
Hesitation or stalling (or both) on MAP engines could have many causes. An EGR valve stuck open would be one problem causing these symptoms. There are many others.
Check engine light on, or was on for a brief time?
Old 01-18-2013, 12:57 PM   #21 (permalink)
somewhere along the way I was mixed up in this question...I don't have a gas smell in camry I do have a bad case of stalling and have been testing and cleaning for three weeks with no change...I am grabbing at straws at this point...no codes
Old 01-18-2013, 03:50 PM   #22 (permalink)
Senior TN Member
That's funny !
You hijacked this thread. The originator, on the 1st post, was asking questions about a gas smell. You jumped in with a totally different topic. I should have suggested you start a new thread, but was trying to help you with your problem on this one.
Anyway, why don't you disconnect the vacuum line at the top of your EGR valve (and plug that hose) and take it for a drive and see if your hesitation and stalling problems subside. Let us know the results.
Old 01-28-2013, 08:51 AM   #23 (permalink)
Senior TN Member
Doctor J's Avatar
Gameroom cash: $359990
View Doctor J's Photo Gallery
Any update on this repair?
87 Camry Station Wagon with A/T and salvage title
Doctor J is offline   Reply With Quote
Old 01-29-2013, 12:50 PM   #24 (permalink)
sorry if I offended anyone by jumping in....I won't be bothering you no mo
