can this cause a gas smell? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2012, 10:21 PM   #1 (permalink)
kobej05's Avatar
Gameroom cash: $134400
View kobej05's Photo Gallery
i have a 93 camry i forgot this has broke but cant this cause a gas smell? thanks
94 Corolla DX 4cyl Auto w/304,XXX
99 Camry LE 4cyl Auto w/104,XXX (Sisters car) m: fearkobe05
kobej05 is online now   Reply With Quote
Old 12-05-2012, 01:08 AM   #2 (permalink)
Tech26's Avatar
View Tech26's Photo Gallery
I think that's just a coolant temperature activated vacuum switching valve. Not likely to cause a gas smell... unless those vacuum lines go to the charcoal canister...?
Tech26 is offline   Reply With Quote
Old 12-05-2012, 02:59 AM   #3 (permalink)
Almost 1/2 Million Miles!
guapoman2000's Avatar
View guapoman2000's Photo Gallery
Certainly not, that is a Water Port Switch and I highly recommend to replace that broken unit and reconnect the hoses to the a new unit!
The listed link is just an example and I would make sure they give you a unit for the make, year and Engine category that you have!
http://shop.advanceautoparts.com/buy...-switches.html
Going back to the Gasoline Smell, this is very Urgent that you get this looked at and find out where the smell is originating from! Engine Fires can and will destroy a car and if you are keeping it in the Garage, it will destroy a house.
Best of luck!!!
guapoman2000 is offline   Reply With Quote
Old 12-05-2012, 10:03 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $726503
View BMR's Photo Gallery
That's a temperature sensor for the EGR system. When the coolant's cold, it's shut and doesn't allow vacuum to pass. When the coolant's warm, it opens and allows vacuum to get to the EGR valve to open it. With the lines broken, the EGR will never open. Is the check engine light on?
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, now at 344k
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 280k
2001 Yamaha FZ1, Ivan's jet kit, resprung, Ohlins rear shock, Race Tech cartridge emulators in forks, 47k miles
BMR is online now   Reply With Quote
Old 12-05-2012, 11:43 AM   #5 (permalink)
Senior TN Member
Gameroom cash: $277505
View 93celicaconv's Photo Gallery
First, what is pictured in the 1st post is a VSV (vacuum switching valve), but it is not used in the EGR (exhaust gas recirculation) system, but rather in the EVAP system, controlling when to open the charcoal canister and pull fuel vapors back into the intake manifold to burn off those vapors.
Below is a vacuum diagram for a 93 Camry V6 (doesn't matter if you have the I4 or V6 engine, the emissions systems are essentially the same):
What is boxed in red is the part you have broken.
Now, what does the charcoal canister do in the EVAP system? Read below, and I think you will have your answer as to why you are smelling fuel vapor:
A charcoal canister is part of the evaporative emission control (EVAP) system in many modern automobiles. The EVAP system is designed to keep gasoline from evaporating into the atmosphere. Rather than venting a gas tank to the atmosphere, an EVAP system can allow fumes to flow into a charcoal canister. This canister contains activated carbon and is thus capable of adsorbing the fuel vapor. This adsorption process, coupled with the closed fuel system, can help ensure that a minimal amount of fuel vapor is allowed to reach the atmosphere.
93celicaconv is offline   Reply With Quote
The Following 2 Users Say Thank You to 93celicaconv For This Useful Post:
Bluegrassman (01-19-2013), BMR (12-06-2012)
Old 12-05-2012, 10:09 PM   #6 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
You're correct about that part's function for the 4 cylinder. And why it could be responsible for the fuel smell. I saw the TVV (a VSV would have an electrical connector) in the pic and remembered how it's used on my 3VZ, which is different than the 4 cylinder. My bad.
However, on the 92-93 V6, it *is* part of the EGR system. The 3VZ has two TVV's, and one of them is part of the EGR control system. And it's not the same as the 4 cylinder or the 94-onward 1MZ-FE V6. Here's the vacuum hose routing label for mine:
Old 12-06-2012, 06:40 AM   #7 (permalink)
Senior TN Member
Yes, you are correct - I just was focusing on the 2.2L 5S-FE, I guess. And the 2nd TVV on a V6 is shaped a bit different than the TVV in the initial thread. My bad.
I think we reached the same conclusion though. The TVV is question, if broken, will cause a fuel vapor smell. It may have already damaged the charcoal canister to the point of no longer being useful (it may be saturated). The place to start is to get the subject TVV replaced and see if, over time, the charcoal canister doesn't impact engine operation.
Old 12-06-2012, 09:57 AM   #8 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
No prob, it's all good. Wasn't the first time I messed up, and I'm sure it won't the be last.
Yep!
Old 12-06-2012, 03:00 PM   #9 (permalink)
christine_lives!'s Avatar
View christine_lives!'s Photo Gallery
There is a purge valve leading out under the charcoal canister if you wanted to check over-saturation.
christine_lives! is offline   Reply With Quote
Old 12-06-2012, 08:26 PM   #10 (permalink)
kobej05's Avatar
sorry for the delay i still have the gas smell. i can smell it on the drivers side. nope it aint parked in the garage. iam worried on day its all gonna blow up on me. i dont see any gas leaks i beleive theres a diffrence on smelling leaking gas and vapor gas. i will have to replace that part. i tried going to the wrecking yard awhile back and i remember seeing cars with caping this water port switch off.
Old 12-06-2012, 08:26 PM   #11 (permalink)
kobej05's Avatar
also there is no check engine light thanks
Old 12-07-2012, 06:36 AM   #12 (permalink)
Senior TN Member
For reference, the only way you can smell gas is from vapor. So whether you see fuel or just recognize the smell, you can't determine if you have a liquid fuel leak or a fuel vapor leak.
Old 12-09-2012, 08:31 AM   #13 (permalink)
Senior TN Member
While out in the salvage yard this weekend getting some replacement parts for a Celica, I found one of these TVV's for the charcoal canister. Based on what I was already getting, I figured they wouldn't charge me any extra for this part. If you want it, PM me - it's yours for the shipping charges.
The Following User Says Thank You to 93celicaconv For This Useful Post:
kobej05 (12-09-2012)
Old 12-09-2012, 01:43 PM   #14 (permalink)
Turbo Snail
Perkins's Avatar
Gameroom cash: $813051
iTrader Score: 7 reviews
View Perkins's Photo Gallery
just go get a TVV from Toyota. They arent that expensive , are they? the TVV gets brittle over time. Thats why yours broke anyways. Might as well get a new one that will last 100,000 miles or more
Perkins is online now   Reply With Quote
Old 12-09-2012, 03:16 PM   #15 (permalink)
kobej05's Avatar
we can give it ago and see if this will solve the problem
