Trouble putting gas in tank - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2012, 08:51 AM   #1 (permalink)
View jrgiancola's Photo Gallery
Hard to put gas in tank of 2001 Camry LE/CLE. A little goes in, then pump stops. Mechanic thought it was some "round thing" that needed replaced. He checked, said that is working OK. So he "blew out" something in the tank. Still have problem. Said thinks I need new gas tank. Any other ideas?
jrgiancola is offline   Reply With Quote
Old 12-07-2012, 09:22 AM   #2 (permalink)
Gameroom cash: $239600
View bolink654's Photo Gallery
I had a Nissan 200SX that would do that. I always thought nissan just put too many bends in the filler neck? Though not like I has another 200SX to compare too. It would work if I didn't use the lock on the pump handle and just manually, sloooowly added gas, so that's what I always did.
Or does the pump kick off even if you try very slow?
1998 Camry - 5S-FE, Auto - 237k
1998 Camry - 5SFE - Auto - 247k
1991 Mr2 Turbo - 243k
1982 Toyota Pickup, 22r, 5spd 4wd, Detroit locker, Warn 8274
bolink654 is offline   Reply With Quote
The Following User Says Thank You to bolink654 For This Useful Post:
jrgiancola (12-07-2012)
Old 12-07-2012, 10:48 AM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $727403
View BMR's Photo Gallery
See if the vent/valve tube is plugged like in this video:
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, now at 344k
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 280k
2001 Yamaha FZ1, Ivan's jet kit, resprung, Ohlins rear shock, Race Tech cartridge emulators in forks, 47k miles
BMR is offline   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
