My car takes a while to shift into gear in the mornings. Any advice? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2012, 08:58 AM   #1 (permalink)
View whitney21's Photo Gallery
I have a 2000 Toyota Camry V6 Automatic
I just had the transmission rebuilt, and everything has been running smoothly, except some mornings I have to push harder on the gas to get the car to move. (If I run the car for 10-15 seconds this doesn't happen) I have a warranty on the new trans so I'm getting it looked at today, but I was just wondering if this will be an easy fix or another big problem? I'd like an idea if I have to plan for someone to pick me up.
Thanks!
whitney21 is offline   Reply With Quote
Old 12-07-2012, 10:12 AM   #2 (permalink)
View zzyzzx's Photo Gallery
Could be anything from the wrong type of transmission fluid, an adjustment, or crap rebuild. My guess is the latter. On an old transmission it's acceptable to have to wait like that (I have been doing it for the past few winters).
If I had to guess and pick one thing, if the fluid is the right type and otherwise OK (and I actually prefer to use the higher Dexron numbers even on an older automatic transmission) then I would be looking to adjust up the transmission oil pump pressure at idle. But again, you shouldn't have to do this on a rebuild. It's something I like to do on an older worn out transmission to keep it going. I did it to my Escort and I am still using the original 1995 automatic transmission with over 210K miles on it.
zzyzzx is offline   Reply With Quote
The Following User Says Thank You to zzyzzx For This Useful Post:
whitney21 (12-10-2012)
Old 12-07-2012, 02:40 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $462410
iTrader Score: 13 reviews
it's common on the transmission to a certain extent- you should let the tranny fluid warm up for a little bit before trying to push the car
similarly, when the tranny is cold, it won't let you go into o/d either
HaHa
The Following User Says Thank You to Eye8Pussies For This Useful Post:
Old 12-07-2012, 03:59 PM   #4 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $741252
View gold94corolla's Photo Gallery
This is what I thought the OP was talking about, and this is perfectly normal.
gold94corolla is online now   Reply With Quote
Old 12-07-2012, 07:48 PM   #5 (permalink)
View nicholas77586's Photo Gallery
AS far as I know this is normal for the transmission to take a while to shift gears when cold. Its just the computer trying to get the engine up to temp faster. Been doing that for the last 185,000 miles on my car.
2012 Camry LE Black With Ivory Interior
Mods:
-Under Dash Lighting
-Fog Light Wiring
1997 Camry Tan XLE V6
nicholas77586 is offline   Reply With Quote
The Following User Says Thank You to nicholas77586 For This Useful Post:
Tags
camry 2000, shift problem, transmission
