Distributor Plug removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2012, 01:52 PM   #1 (permalink)
View ssulaco's Photo Gallery
2000,Camry,Auto.2.2L
I'm wanting to purchase the Dist Plug,Not sure where to get it, oReilly's doesnt show it,Would this be a dealer item? Mine is leaking
Would I be able to remove the plug without removing the VC? It has been recently resealed
and if I can what is the best way of removing the plug
or should I just try to cover the plug with a good sealant....Thanks
ssulaco is offline   Reply With Quote
Old 12-25-2012, 04:47 PM   #2 (permalink)
View 1996camry's Photo Gallery
stop by your local Toyota dealership, you can get that seal for just 8 bucks. I advise to replace a new seal, if you try to reused the seal, you will see oil leaks again. i replaced the new seal on my 2000 Toyota Camry. the oil stop leaks.
please bring your old seal with you to show the part guys... if i remember, they call seal.. WHEN you're ready to install a new seal back, please add sealant before reinstall. DO NOT PUT SUPER CLUE OTHER THAN SEALANT WHEN REINSTALL THE SEAL. ONLY APPLY SEALANT AROUND THE SEAL BEFORE REINSTALL BACK.
1996camry is offline   Reply With Quote
Old 12-26-2012, 07:17 AM   #3 (permalink)
I will give them a call first to see if they know what I'm talking about...Thanks
Old 12-26-2012, 11:33 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $713803
View BMR's Photo Gallery
No need to replace it unless it's cracked or distorted. It's just a plastic disk with no seals. It's held in place with silicone sealant. Break it out and clean it up really good with some type of solvent. Then reinstall it using Permatex Ultra Black or equivalent; there are many.
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, now at 344k
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 280k
2001 Yamaha FZ1, Ivan's jet kit, resprung, Ohlins rear shock, Race Tech cartridge emulators in forks, 47k miles
BMR is offline   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
ssulaco (12-28-2012)
Old 12-26-2012, 01:35 PM   #5 (permalink)
I don't agree at all. hot and cold will shrink the rubber enough to allow the rubber material break down. if you don't believe me, I did re-used the rubber. the oil still leak after put siilicon ... finally, i end up removed again..and put a new rubber or seal. the oil leaks is now fixed.
Old 12-26-2012, 02:30 PM   #6 (permalink)
View Vibe's Photo Gallery
I just did this to my car....when I was doing my research I went to a Toyota dealership to buy the Plug...the parts guy could not figure out what part it was. He took me to the garage and got a Tech for me. The tech told me it was not necessary to buy a new one just clean it up and reseal it.....obviously if it is cracked that is a different thing.......You said it was resealed already and leaked?.......did you pull it all apart and reseal it with permatex gray the first time?.....did you pull up the half moons and reseal them?.......did you put gray on the 8 recommended spots?......find the thread that I have about this.....and read it........I believe the consensus for the VC nut torque is 20psi.....
1998 Camry, I4, Auto
2006 Vibe, Auto, AWD
Vibe is online now   Reply With Quote
Old 12-26-2012, 10:45 PM   #7 (permalink)
Originally Posted by Vibe View Post
I just did this to my car....when I was doing my research I went to a Toyota dealership to buy the Plug...the parts guy could not figure out what part it was. He took me to the garage and got a Tech for me. The tech told me it was not necessary to buy a new one just clean it up and reseal it.....obviously if it is cracked that is a different thing...(Why would Toyota not have this in Parts breakdown of the Head)....You said it was resealed already and leaked?(The VC had been resealed.......did you pull it all apart and reseal it with permatex gray the first time?.....did you pull up the half moons and reseal them?(What are the Half moons?).......did you put gray on the 8 recommended spots?......find the thread that I have about this(You have a Link?).....and read it........I believe the consensus for the VC nut torque is 20psi.....
Old 12-27-2012, 08:16 PM   #8 (permalink)
did you call Toyota Dealership asked the seal? Did the part guy relocate the part# for you?
if you can't find, i can do for you. give the car info..
Old 12-27-2012, 10:21 PM   #9 (permalink)
I don't have a Toyota dealership close by,but do have a Hyundai dealer I use to get my Toyota parts,hopefully will get back with me tomorrow,will let you know,Thanks.
Old 12-28-2012, 07:00 AM   #10 (permalink)
I don't know why Toyota did not have the part or why the toyota parts guy could not find it........incompetance I would assume.......The tech however knew all about it...
the reason it leaked is because you did not reseal the plug and the half moons.....my guess is that plug is fine.......
Go to my name and search my posts and the threads I started....if you read all my posts about this topic and the thread I starterd you will learn everything.........all the questions will be answered....
You sound like a NOOB so I will give you some advice..It is all about preparation......you will be better off studying the threads and reading and watching videos of this or any repair for an hour or 2.......then gather everything you need and ..then do the job..you will only have to do it once....I am guessing you are on the second repair of this job because of lack of preparation .....it took me 1.25 hours of pretty painless work to do mine.......so far so good.....
Old 12-28-2012, 07:03 AM   #11 (permalink)
there are a few members on here that really know there stuff........BMR is one of them........you do not need the plug. look at the plug if it is not cracked and it does not look cracked to me then you can reuse it.......you need some permatex Gray........and a torque wrench....
Old 12-28-2012, 10:11 AM   #12 (permalink)
These are the Half Moons (Semi-Circular Plug)?
Old 12-28-2012, 11:10 AM   #13 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Yes. Halfmoon plug = semi-circular plug. Those are aluminum. No need to replace those either, unless they're damaged in some way. They're also held in with sealant. To get them out, use a visegrip or pliers and lift up with a little rocking motion. The old sealant should let loose with a little persuasion.
Also, put a dab of sealant at the corners, where the gasket goes up and over the cam journals.
Here's a link to Vibe's thread. There's a lot of good tips sprinkled all over, so read the whole thing closely... Leak at the plug where the old distributor went?
The Following 2 Users Say Thank You to BMR For This Useful Post:
ssulaco (12-28-2012), Vibe (12-28-2012)
Old 12-30-2012, 08:54 AM   #14 (permalink)
Thanks,Gents for Info,wont be able to get to it this weekend,hopefully next weekend.
Old 01-12-2013, 05:56 PM   #15 (permalink)
Cleaned and resealed Dist plug using Permatex-the right stuff,manufacturer of the plug is by NOK it is EZ9017A.
BMR you were correct, wasn't a thing wrong with the old plug,Thanks
