common problems with the 1997 camry's - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-26-2012, 12:05 PM   #1 (permalink)
View mrtimo's Photo Gallery
Considering buying a 4th gen Camry. 1997 w/165k miles. Wires, Plugs recently replaced. Don't know too much else about it. Considering paying $2500 which seems high, but I am buying from my Brother... he was recently gifted the car.
What are common things that go wrong in Camry's from 165-240k miles? Timing Belt, Transmission, Engine, Water Pump?
Is this a good buy?
mrtimo is offline   Reply With Quote
Old 12-26-2012, 12:26 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $713403
View BMR's Photo Gallery
At that mileage, it's due for quite a few things, like any car would be. To me, that's a fair price if it's in decent shape. Engines and trans are pretty solid if given decent care.
Rack & pinion is somewhat prone to leaks.
Timing belt - non interference engine, so it's not critical to change.
Struts
CV axles
Radiator/cooling system.
Parts are cheap though, so if you're a DIY'er, none of that should scare you off.
Also, '97 was included in Toyota's sludge settlement. IMHO, not a big deal if the oil changes were done reasonably frequently. Only way to really know is to pull a valve cover and have a look. Is this a V6 or 4 cylinder?... not that it really matters.
http://www.consumeraffairs.com/news0...ettlement.html
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, now at 344k
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 280k
2001 Yamaha FZ1, Ivan's jet kit, resprung, Ohlins rear shock, Race Tech cartridge emulators in forks, 47k miles
BMR is offline   Reply With Quote
Old 12-26-2012, 01:23 PM   #3 (permalink)
Thanks for the info.
Old 12-26-2012, 02:34 PM   #4 (permalink)
Senior TN Member
... rack and pinion maintenance
... My 98 XL had leaking rack and pinion hydraulic seals when i got it a few years ago. I noticed that the hydraulic fluid reservoir, next to the upper fender in the engine compartment had some very black colored fluid. i emptied the dirty fluid and replaced it with the appropriate type ... This was just transmission fluid, if i recall correctly for this car. ... At any rate, after
several cycles of driving, emptying, and refilling with clean fluid, the hydraulic seals no longer leak. The fluid in the hydraulic reservoir is always at the same level. I still empty and refill the hydraulic reservoir bottle with clean fluid at every oil change, about once a year.
... I think the clean hydraulic fluid was able to recondition the seals, at least to the point that they don't leak. I think I have avoided a major repair by using this procedure. I would advise you to try it, before you have any problems of this nature.
... Also, you should not hesitate to get the timing belt, water pump, and thermostat replaced if there is any question at all about their condition.
98 Camry LE, 2.2L, automatic
53k miles, drop in K&N A/F
... timing belt, water pump
Old 12-26-2012, 02:36 PM   #5 (permalink)
View Vibe's Photo Gallery
Struts
CV axles
I agree with BMR......if it is in good shape it is worth $2,500......It is a good habit to answer what ever questions you can on this forum.....it helps to have details BMR was wondering what engine it has?.........................I am wondering if you have any mechanical skills? have you done any work on cars before?............also if you do get the car go to control panel and create a detailed signature of the car......Welcome!
1998 Camry, I4, Auto
2006 Vibe, Auto, AWD
Vibe is online now   Reply With Quote
