weird noises when gear in reverse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2013, 03:19 PM   #1 (permalink)
Senior TN Member
Gameroom cash: $484345
View adalex's Photo Gallery
4th Generation weird noises when gear in reverse
Hey guys I have a 99 camry I4 le, I've noticed for a long time that after i put my car in reverse and use the gas to back up quickly its kinda like a metallic crunching noise. im just shy of 130k and the tranny doesn't slip at all and everything is good I was just wondering if thats normal? if i back up my brothers 05 acura tsx its a whining noise? any thoughts? I was thinking thats normal mainly because its not like ive been driving fast and then randomly shifted into R w/o stopping (as I would imagine would kill the tranny)
any thoughts would be appreciated
If you find my post helpful, please use the button
adalex is online now   Reply With Quote
Old 01-01-2013, 03:20 PM   #2 (permalink)
Senior TN Member
oh and just to reiterate if I just backup out of a parking spot or something just using the brake and not using the gas it doesn't do it and goes fine. its when i use the gas like to backup quick if traffic is coming that it does it
Old 01-01-2013, 05:22 PM   #3 (permalink)
Ambitious but Rubbish
Reilly 3VZ-FE's Avatar
View Reilly 3VZ-FE's Photo Gallery
Sounds like from what you describe that your car either has old or low auto trans fluid. I would recommend doing an ATF change right away so that it does not wear down the transmission. When gears sound crunchy and grindy, it's never good.
5S-FE 4AT - - - - - - - - 3VZ-FE 5MT - - - - - - - PARTS CAR
Reilly 3VZ-FE is offline   Reply With Quote
The Following User Says Thank You to Reilly 3VZ-FE For This Useful Post:
kobej05 (01-01-2013)
Old 01-01-2013, 10:14 PM   #4 (permalink)
Senior TN Member
I'm at work now but when I leave ill do a video so u can hear, like I said its only when I press the gas hard to back up quick. Otherwise it doesn't do it
Sent from my SAMSUNG-SGH-I897 using AutoGuide.Com Free App
Old 01-01-2013, 10:48 PM   #5 (permalink)
Senior TN Member
Gameroom cash: $303855
View deadrx7conv's Photo Gallery
Well, avoid pressing the gas hard when reversing.
When reversing, you're drivetrain shifts and rocks. Any loose or questionable motor mounts will cause noise.
When reversing, all your brakes 'shift'. Then, they'll shift again when going forward.
When reversing, all your inner/outer cv's will also switch load direction and make noise. Any cv leaks or torn/missing boots is an issue. If original, I'd be gentle with them.
As with any transmission, fresh fluid in the transmission and its differential could help mask some wear related noises. Change it out.
Reverse, like low, should also compression brake which adds some noise versus freewheeling. See how it sounds like in low-1st gear.
deadrx7conv is offline   Reply With Quote
Old 01-01-2013, 11:43 PM   #6 (permalink)
Gameroom cash: $438276
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Crunch noises are synonymous with fucked synchros.
FOR SALE: || Lexus ES300 1997-2001 Rear Brembo Rotors || 3SGTE OEM Parts || H&R 15mm DRS Spacers (for all Toyota's)
MR2: 436whp-354lb/tq!!
RichieRichJP is offline   Reply With Quote
Old 01-01-2013, 11:44 PM   #7 (permalink)
Senior TN Member
Well that would explain after I go backwards and use the brake I would here a metallic clank from the front wheel, the local parts guy at the dealership said it might be the slider pins. I finally figured out how to take the boots off thanks to somebody who explained it in another thread I started and messed around with another caliper bracket. I have a set if slider pins for both sides as well as bushings and the rubber boots on Gary which said he should be order them later today. As far as the tranny fluid I'd have to check but I know for sure the differential fluid was changed like 5 days or so before Christmas last year. From the look of it, it had never been changed
Old 01-01-2013, 11:48 PM   #8 (permalink)
Senior TN Member
I want to say I changed the tranny fluid sometime earlier last year not sure when but I only put like 11k miles or so on the car a year
Edit: I just looked I changed the differential fluid on 12/17/11 at 120,720, I'm sitting in the car right now and I'm at 129,554, let me do the video
Old 01-02-2013, 12:29 AM   #9 (permalink)
Well I stand by the synchros being bad, but its hard to tell without physically seeing and hearing it.
As for your bro's car, sounds like his TO bearing is done for.
Old 01-02-2013, 12:43 AM   #10 (permalink)
Senior TN Member
whats the technical term for the synchros? so i could look it up on sites?
Old 01-02-2013, 02:52 AM   #11 (permalink)
Senior TN Member
ok heres two videos, first is me trying to get it to make the sound. the second is me driving home (just showing how flawless,smooth etc the shifts etc are)
again any thoughts/advice what i should check(assuming anything is actually wrong)
would be greatly appreciated
Old 01-02-2013, 08:37 AM   #12 (permalink)
Asks many questions .....
LE PEW's Avatar
View LE PEW's Photo Gallery
I may have missed it but just for the sake of clarity do you have an automatic or standard transmission. I ask because I see discussions of both trans fluid and synchronizer rings??
Thanks.
1994 Camry LE V6 156,000 miles
1995 Camry XLE V6 81,000 miles
LE PEW is online now   Reply With Quote
Old 01-02-2013, 10:55 AM   #13 (permalink)
Senior TN Member
Auto, I don't know what synchronizer rings are
Old 01-02-2013, 11:14 AM   #14 (permalink)
Senior TN Member
it was when i backed up at 0:50, it didn't really do it so much though, could it be possible for it do make a sound if im driving and stop and flip to reverse really quickly and press the gas to back up quick?
Old 01-02-2013, 12:46 PM   #15 (permalink)
Hmm, don't think the auto has those.
Can't think of what else that sound can be.
