Fast Idle Speed on V6 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 14 Old 01-07-2013, 12:12 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have fast idle speed issue with my 300K miles 1994 V6 1MZ-FE engine. Idle speeds showed 2000 RPM at when cold and 1250 when warmed up. Normal RPM should be 700. I sprayed choke cleaner to check for vacuum leaks on every vacuum tubings, on throtle valve body, intake manifold, PCV (replaced), and air filter assembly but could not find any leaks as indicated by RPM not changing. I disconnected electrical plugs connection to IAC, throtle position sensor, temperature sensor and Mass Air Flow sensor to look for RPM changes. They all worked fine. I even replaced with another throtle valve assembly and MAF that I removed from another Camry from junkyard. But none of these corrected the high idle speed problem. I've already spent three days working on this issue and don't know what else to do next. I would appreciate if you guys can suggest what else to look for. Please help. Thanks.
Chiman1 is offline
post #2 of 14 Old 01-11-2013, 02:12 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Does anyone know what to do? Thanks.
Chiman1 is offline
post #3 of 14 Old 01-11-2013, 04:06 PM
Asks many questions .....
LE PEW's Avatar
Quoted: 0 Post(s)
Have you tried cleaning the IAC yet? I would also check to see it there is enough slack in the throttle cable to let it return.
Good luck.
1994 Camry LE V6 156,000 miles
1995 Camry XLE V6 81,000 miles
LE PEW is offline
post #4 of 14 Old 01-14-2013, 01:01 AM
Avarollin?
Jigg007's Avatar
Quoted: 3 Post(s)
I have a 1MZ on a 96 Avalon, I too witness 2krpm cold idles. 32F and below. If it is REALLY cold like picking around 10F, it will start around 1.5k and ramp up to nearly 2krpm.
I was digging around a bit, and some 1mZ camry dudes mention they also have 2krpm cold idles, but the majority seem to rest at 1.5krpm.
Though sometimes when my car heats up -the temp gauge hangs in the middle, but just got there, like a 5-8 minute trip at 20F, it will idle at 1krpm in park. But the car appears to run fine. If I run longer, like 15 minutes I'll be idling at 700. It sounds similar to your situation but given time it corrects to a normal rpm.
Thought I'd chime in to let you know you're not alone, and to sub to the thread.
If that's normal, thats cool. Otherwise I don't think 2000 rpm with ice cold oil is the best thing ever.
Jigg007's 1996 Toyota Avalon
250A Alternator
2500W AC Inverter
3200W Sound system
Windows 7 Carputer
Onboard Air System
D2 Street Coilovers
Jigg007 is offline
post #5 of 14 Old 01-14-2013, 06:12 AM
LE PEW's Avatar
Quoted: 0 Post(s)
I have 2 1MZs a 94 and a 95. The 94 only goes up to 1800 and settles into a 750 rpm idle. The 95 goes up to 2000 and settles into a 700 rpm idle. I'm guessing both are acceptable. The idle on both begins come down lower after just a few minutes of warm up time.
Both have had their IACs cleaned out. And although I havent done so myself, there is some adjustment to be made on the IAC.
Good luck.
LE PEW is offline
post #6 of 14 Old 01-14-2013, 12:02 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
High idle speed.
Thanks everyone for the reply. There is enough slack on the throttle cable so that's not the problem. I will clean out the IAC valve next as suggested. Meanwhile, I managed to reduce RPM from 1200 to 800 after engine is warmed up by disconnecting the rubber hose between the IAC valve and plugging off the vacuum between the "airpipe" to front and rear intake manifolds. It seems like a temporary fix but don't know why this works. I have a picture, but don't know how to post it. Sorry.
Chiman1 is offline
post #7 of 14 Old 01-14-2013, 02:21 PM
BMR
Deputy of Mayberry
BMR's Avatar
Quoted: 624 Post(s)
How to post pictures
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 26k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 347k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #8 of 14 Old 01-26-2013, 11:42 AM
LE PEW's Avatar
Quoted: 0 Post(s)
Update:
I was cleanig the IAC today by spraying carb cleaner into the opening in the trottle body using a straw on the spray can. I know it's not as effectife as actually removing the IAC from the throttle body but it's cold outside!!
Anyhooo, as I was spraying into the throttle body I wondered how well it was actually cleaning and if the rotor was turning freely. I considered running power to the Iac motor to exercise it while spraying but it was too cold outside and too much involved to run cables to it.
I wound up just removing the 2 philips screws and letting the IAC motor hang from the connector wires. With the shaft exposed I could spray the cleaner while turning the shaft back and forth by hand through the range of motion. It turned out to move very freely and I could actually feel the resistance of the spring on the other side of the IAC shaft.
Well to make a long story a little longer ... while putting the IAC motor back onto the throttle body I noticed that the two screw holes were elongated to allow for some adjustment. Then came the Oh $hit moment when I realized that I didnt mark the original position because I didnt know it was ajustable. I wound up installing it back on the car leaving the 2 philips screws loose enough to allow for rotation of the IAC motor.
I started the car and to to my surprise I could change the cold idle speed a great deal by rotating the IAC motor CW and CCW!! This was quite a revelation to me because I always believed that cold idle RPM was fixed!
I woud up setting the cold idle at 1600 RPMs with an outside air temp of 19 F.
I will follow up on driveability and warm idle speed but for now it seems like a feasible option for those who are concerned with higher cold idle RPMs.
Was anyone else aware of this capability, and will I freak out my ECU by changing the original IAC motor setting?
LE PEW is offline
post #9 of 14 Old 02-22-2017, 06:10 PM
Quoted: 2 Post(s)
Le Pew. What is the CW and CCW? My issue might be related. I'm experiencing a high idle even after warm-up. Engine used to idle at around 750rpm but now idles at 1000 rpm.. My cold start is at around 1500 rpm. I would like to reduce the cold start idle to about 1200 and fix the high warm up speed back to 750rpm. Anyone out there have an educated repair idea?
ferrari is offline
post #10 of 14 Old 02-22-2017, 07:06 PM
Sr. Member (アンソニー ムクゴーアン)
mcgowaw's Avatar
Quoted: 843 Post(s)
is this high idle new or has it always done this?
has regular maintenance been done including cleaning the intake and throttle body and replacing plugs/wires/pcv/rotor/cap as applicable?
assuming your's is a MAP equipped engine, check out that sensor as high idle is a symptom of a bad map sensor.
tony
1994 Camry, V6 XLE 3.0, 1MZ-FE, A541E (4-speed)
2001 Sienna, V6 LE 3.0, 1MZ-FE, A541E (4-speed)
2006 Camry, I4 LE 2.4, 2AZ-FE, U250E (5-speed)
mcgowaw is offline
post #11 of 14 Old 02-22-2017, 08:06 PM
Quoted: 2 Post(s)
McGowaw This just started up right after replacing a leaking power steering resevoir hose. Never cleaned the throttle body or intake. Done all other service regularly. You think that it is not a dirty IAC valve? Do you know if there is there a simple way to check the MAP?
ferrari is offline
post #12 of 14 Old 02-22-2017, 08:41 PM
mcgowaw's Avatar
Quoted: 843 Post(s)
well, since i have no idea what model, engine, etc., you have or the miles or the maintenance history, this is a shot in the dark but did you remember to hook up the hose to the map sensor and the other hoses too?
mcgowaw is offline
post #13 of 14 Old 02-22-2017, 09:39 PM
Quoted: 2 Post(s)
98 Camry V-6 180,000 miles. All hoses connected. Never removed them.
ferrari is offline
post #14 of 14 Old 02-22-2017, 09:55 PM
mcgowaw's Avatar
Quoted: 843 Post(s)
there's a testing procedure in the fsm and probably haynes too, at least for the gen3 i4. not sure about the gen4 i4. could always put a junk yard pull in there to see if it helps. this assumes you have no obd2 dtc's. if you do have a cel, can you give us the freeze frame data? what are the short and long term fuel trim percentages at idle and 2500 rpms?
tony
mcgowaw is offline
User Tag List
Linear Mode Linear Mode
« Back
