Can I get my "cigarette lighter" to stay on all the time? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2013, 09:57 AM   #1 (permalink)
View Vibe's Photo Gallery
I stooped by a stealership and they said it can't be done. I want my power port/cigarette lighter to be on all the time so I can charge my phone. Does anyone know if it can be done?
1998 Camry, I4, Auto, 130k. (sent from my Droid Bionic)
2006 Vibe, Auto, AWD
Vibe is online now   Reply With Quote
Old 01-14-2013, 11:03 AM   #2 (permalink)
Gameroom cash: $280065
iTrader Score: 10 reviews
View slavie's Photo Gallery
It's an "accessory", along with your stereo and other things. All accessories are powered up when you turn your ignition key to "acc" mode, which is the first click, and turned off when you remove the key. This is so that you don't drain your battery by forgetting to turn something off.
You can make it work, but your would need to re-wire it so that the port is powered directly from the battery, and you would need to add an appropriate fuse into the equation. If it's a low-power device, you can even tap into the 12v constant that is fed to the radio (to keep radio memory), but you have to be very careful then not to plug any higher powered device into the port as that will blow a fuse somewhere - you have to know what you're doing if you want to go this route. Not impossible, but requires a bit of fiddling.
slavie is online now   Reply With Quote
Old 01-14-2013, 11:16 AM   #3 (permalink)
Senior TN Member
71Corolla's Avatar
Gameroom cash: $817350
View 71Corolla's Photo Gallery
To do this, go to a salvage yard and get part of the wiring harness that plugs into the cig lighter socket. Run that from the socket to the steering column and connect to the white/red stripe wire (could be solid white) using an inline fuse holder.
Always be very careful not to run wiring that will get tangled up with the accelerator and brake pedal.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 01-14-2013, 11:46 AM   #4 (permalink)
Gameroom cash: $103535
View AlmightyCamry777's Photo Gallery
Its a piece of cake to do this! I had to do this once for another car - I wanted to use a solar battery charger. The easiest way is get some wire - 10 gauge is the usual size - a fuse tap and some solderless connectors (assuming you don't want to solder). A fuse tap is simply a small piece of metal that let's you tap into the fuse box. Tap into something that uses the same voltage and has power all the time (the number on the fuses plus you're owners manual will tell you what you need to know). Pop out your cigarette lighter socket and use the solderless connectors to re wire the socket. I suggest by passing the existing wiring completely, just run a new wire - as already mentioned be sure and splice in a fuse holder in line with the wire.
AlmightyCamry777 is offline   Reply With Quote
The Following User Says Thank You to AlmightyCamry777 For This Useful Post:
Vibe (01-15-2013)
Old 01-14-2013, 12:22 PM   #5 (permalink)
Daijoubu's Avatar
View Daijoubu's Photo Gallery
Does that mean a solar charger plugged into the cig lighter does nothing?
The weird thing is that if I put a voltmeter on the cig lighter, it it will show me the battery reading, how is that possible?
Daijoubu is offline   Reply With Quote
Old 01-14-2013, 01:53 PM   #6 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $714303
View BMR's Photo Gallery
Just another option, if your phone cable plugs into a USB port. Leave the lighter socket alone and add this bulkhead connector somewhere. It's a little spendy at $37 though.
http://www.amazon.com/BLUE-1016-CHARGER-SOCKET-PORTS/dp/B00AS4J2Y8/ http://www.amazon.com/BLUE-1016-CHARGER-SOCKET-PORTS/dp/B00AS4J2Y8/
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, now at 344k
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 280k
2001 Yamaha FZ1, Ivan's jet kit, resprung, Ohlins rear shock, Race Tech cartridge emulators in forks, 47k miles
BMR is online now   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
Vibe (01-15-2013)
Old 01-14-2013, 02:13 PM   #7 (permalink)
...not to mention $9 shipping. It's a much better idea, though, as you don't run the risk of someone plugging something into the power outlet and forgetting about it, draining your battery or blowing a fuse. At least with this dedicated plug, your car's original design isn't impacted much, and there are no power hungry USB devices.
Oh, and here's one for $25 + free shipping :
http://www.newegg.com/Product/Produc...9SIA1260CF6713
or $18+ S&H
http://www.sierraexpeditions.com/ind..._detail&p=8670
Old 01-15-2013, 05:54 AM   #8 (permalink)
Thanks for the ideas. I like BMR's idea the best. I'll let you know if I do it.
Old 01-15-2013, 05:55 AM   #9 (permalink)
Thanks for the info about the fuse tap
Old 01-15-2013, 10:51 AM   #10 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Thanks Vibe, but I gotta 'fess up and say I stole it. I forget who posted it and where; might've been the "What did you do to your Camry today" thread. I've been thinking of doing it myself too. It'd be nice to have a way to charge up an iPod or phone while it's sitting in the car in the parking lot. I'm still deciding where I'd mount it, so I'd like to see what you do.
Old 01-15-2013, 11:48 AM   #11 (permalink)
Gameroom cash: $211200
View RonR's Photo Gallery
Playing the devils advocate, I would be a little concerned over any device connected directly to the battery, anything that can draw power when key is off.
If you have an automatic transmission you are hooped if battery level gets to low.
I know "it will never happen" but batteries do get older and hold less power, so can strand you if you don't watch for the signs.
Adding a direct draw also adds the possibility of an out of spec current draw, more power being drawn than you counted on.
For this type of thing I might look at adding a smaller 12v battery mounted in the engine compartment and charged by the alternator via an isolator, then hook that battery to the 24/7 outlet.
RonR is online now   Reply With Quote
Old 01-15-2013, 12:04 PM   #12 (permalink)
Daijoubu's Avatar
You can also add a auto shut off circuit when voltage drops below a certain point and/or a separate switch
Edit: I couldn't find any cheap, readily available circuit on eBay but here's a sample design from MAX with a very low quiescent current
http://www.maximintegrated.com/app-n...ex.mvp/id/2015
Old 01-15-2013, 05:14 PM   #13 (permalink)
Gameroom cash: $225800
View bolink654's Photo Gallery
Or what about a solar panel sitting on the dash that would keep the battery topped up while charging something?
1998 Camry - 5S-FE, Auto - 237k
1998 Camry - 5SFE - Auto - 247k
1991 Mr2 Turbo - 243k
1982 Toyota Pickup, 22r, 5spd 4wd, Detroit locker, Warn 8274
bolink654 is offline   Reply With Quote
Old 01-15-2013, 07:10 PM   #14 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Yeah it should definitely be fused. That goes without saying. I might tie into the existing lighter wiring, in which case I don't think it's necessary as that is already fused. But I'll check the fuse amperage Vs nominal current draw of the lighter to be sure there's enough headroom for another 1 amp draw (roughly what that should take). And the power draw of an iPod or iPhone charging like this is so minimal, if it drains the battery... well, it was probably taking its last breaths anyway.
Old 01-16-2013, 12:17 AM   #15 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $1165210
View BamZipPow's Photo Gallery
The power outlet has it's own fuse and direct circuit. This is the only one I would jumper. Do not jumper the Cig lighter circuit!!
Pull the 15A Stop fuse
Pull the 15A Power Outlet fuse
Install a mini fuse Add-a Fuse power tap into the Stop fuse slot
Install both 15A fuses into the power tap
Route the power lead into the Power Outlet side (not the 12V side of the fuse slot) using a power tap accessory. You can use a burned out fuse to keep the tap in place. Do not use a working fuse!
This will provide constant power to the Power Outlet until you pop the fuse.
Add-a-Fuse mini fuse tap
Amazon Amazon
Power tap installed under the fuse...
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
BamZipPow is online now   Reply With Quote
