'96 4 cyl oil & trans fluid leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2013, 03:30 PM   #1 (permalink)
View myname's Photo Gallery
It's time to get these leaks taken care of. Been avoiding them for some time but can't any more. There's 4 leaks: ps pump intake and suction hoses, trans pan gasket, oil leaking into the distributor and oil leaking from the oil pump and apparently out of the pan.
After looking at the online manual I've become pretty comfortable with tackling all of them. However, the oil pump seems a bit intimidating so I'd like to ask what others found helpful when this was done?
myname is offline   Reply With Quote
Old 01-17-2013, 10:17 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $713703
View BMR's Photo Gallery
There are a few threads about the oil pump in the DIY thread stickied at the top of the Gen 3/4 Camry forum:
Camry FAQ ------> READ FIRST -----> Comprehensive List of Gen 3/4 INFO and DIY
DIY: 5sfe Oil Pump Diagnosis
DIY: GEN3 Timing Belt + Waterpump + Oil Seal Change - Part 1
DIY: GEN3 Timing Belt + Waterpump + Oil Seal Change - Part 2
Part 1: Timing Belt and Oil Seals Replacement (w/ Pictures)
Part 2: Timing Belt and Oil Seals Replacement (w/ Pictures)
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, now at 344k
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 280k
2001 Yamaha FZ1, Ivan's jet kit, resprung, Ohlins rear shock, Race Tech cartridge emulators in forks, 47k miles
BMR is offline   Reply With Quote
Old 01-18-2013, 09:15 AM   #3 (permalink)
When you do something new and unfamiliar, it is really nice to have a friend that'll help you out. That's what this site is all about.
Just to note, to take care of the leak problems it would cost $2,720.00 US, at an independent garage.
Thank you for pointing out what I'd missed, those links are amazing!
So far on this site I've been a consumer but hopefully I can contribute at some point.
Also, thanks to dz63 and all the others who contributed to making all this available
Old 01-18-2013, 10:34 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
You're quite welcome! Yes, those DIY threads are great. Seeing pics and getting pointers from someone who's done it is the best.
