98 headlights to 2000 headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-26-2004, 04:40 PM   #1 (permalink)
View bush's Photo Gallery
How can I convert 1998 headlights to 2000 headlights. Is there a way to splice the wires so that it would work?
bush is offline   Reply With Quote
Old 07-26-2004, 05:05 PM   #2 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
alot of work
first of totally different size unit, ulll need new bumper, fender, corners, and hood
And also the wiring is completely different they use dual ballasts unlike us that have one bulb double filament
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 07-27-2004, 12:52 AM   #3 (permalink)
View woshiagni's Photo Gallery
Re: 98 headlights to 2000 headlights
Yes, wiring up a custom harness is simple, getting the actual body parts (bumper/grille, corner lights, headlamp assy) costs $$$$.
For each side, you basically need three main parts (not including the wires you'll need to solder up):
1) Find an old 9003/H4 bulb and break it so you have a "socket" that will fit your current headlight connector (or just buy a reverse 9003 socket, although I haven't seen these around before). You will also need 2) a 9005 socket and 3) a 9006 socket to plug into your new bulbs. Solder the ground and 12v connections between the 9003, 9005, and 9006 sockets and your good to go.
woshiagni is offline   Reply With Quote
Old 10-14-2006, 08:40 PM   #4 (permalink)
View charlieb99le's Photo Gallery
4th Generation
know would that be the same witha 99 and how exactly do u wire them in all together?
charlieb99le is offline   Reply With Quote
Old 10-14-2006, 09:06 PM   #5 (permalink)
97trdcamry's Avatar
View 97trdcamry's Photo Gallery
I recently did the conversion without swapping the bumper or anything. A little cutting here and a little trimming there, and they are beautiful. All the tools you need is a razor blade, a dremmel, and a big c clamp. no to mention alot of patience.
For the wiring, I purchased a high wattage headlight wiring kit for 9005 / 9006, and I used a H3 high wattage harness adapter so I did not have to cut my factory wires. I took some pics and I plan to do a detailed write-up sometime soon.
97trdcamry is offline   Reply With Quote
Old 10-15-2006, 05:18 AM   #6 (permalink)
Car Geek
View skywise's Photo Gallery
I'm eagerly awaiting your writeup.
I've been drooling over 2000+ headlights since I got my '99
skywise is offline   Reply With Quote
Old 10-15-2006, 11:13 AM   #7 (permalink)
4th Generation
were did u get those from i looked on ebay for the 9005/9006 kits but im not sure if its the rite thing. and i cant find the the harness to connect to the factory harness
Old 10-15-2006, 06:30 PM   #8 (permalink)
97trdcamry's Avatar
I purchased the following items:
High wattage harness for 9005 / 9006 (part # Part # CSI/WIR-9005-9006 ) from this eBay seller :
sevensat. it was item number 290030986506. Total cost was $38.00 including shipping. You can go to sevensaturdays.com and give them the part number and they should be able to get one for you. It is a really high quality harness and when I cut my high beams on, the low beams stay on as well. It's great!!
H4 wiring harness:
http://cgi.ebay.com/ebaymotors/H4-so...mZ220037167775
Total cost is $17.94 including shipping. All you really need is one male H4 end to wire into the other harness and to plug into the factory female H4 end of the oem headlight harness. I purchased this item, and I have an extra one because it came with two. I'll sell it to you for $10 shipped if you are interested.
Hope this helps!!
Old 10-16-2006, 12:10 PM   #9 (permalink)
View leasaunce's Photo Gallery
alot of work, and this topic has been covered alot of times before
"Search" and you shall find your answer
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
