92 le Wiper problem (advice needed) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-27-2004, 12:42 PM   #1 (permalink)
View mikerowesoft's Photo Gallery
Angry 92 le Wiper problem (advice needed)
The wiper of my 92 le camry seized up, so I took out the linkage system and using a full can of wd-40 and a day of patience, I was able to loosen the seized up component of the linkage.
I later re-installed the linkage and ran into the following problem: The wiper no longer parks when the wiper switch is turned off, but simply stops when switched off. In addition, the wiper only moves when the wiper switch is in the "fastest" position, and it moves at roughly the speed of the "low" position.
Has anyone run into this type of problem before? Any advice on this will be very much appreciated.
Thanks....
mikerowesoft is offline   Reply With Quote
Old 07-27-2004, 01:56 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
if you ask me, it seems like the linkage should reallly be replaced
tho you did unsieze it w/ wd40, it won't last long unless you use more lasting grease, but more so the fact that it seems it only moves when the motor is at the fastest and most powerful setting, hence the fact that it doesn't come to rest and just stops and only moves when at the fastest setting
HaHa
Old 07-28-2004, 08:51 AM   #3 (permalink)
Thank you for your input Eye8Pussies. I plan to further lubricate the linkage with permanent grease like you seem to suggest, and if this fails, then I guess I will have to fork out some paper for a new linkage Does anyone know how much a new 92 wiper linkage will cost?
Old 07-28-2004, 11:52 AM   #4 (permalink)
TN Pussy Man
junkyard
HaHa
Old 08-06-2004, 08:45 PM   #5 (permalink)
sleekaman's Avatar
View sleekaman's Photo Gallery
Same problem
Imagine, I had the same problem as you. I brought it to the Dealer and they diagnosis it as been the linkage also. They said if I dint' fix the linkage, your wiper motor will cease also. So they recommended a whole re/re of the linkage. They took it apart, and cleaned it and lubed it with whatever they use, and voila, its been working fine, done say around 4 years ago.
Harvey.
07 Camry V6 XLE (Family Cruiser)
03 Corolla LE (Daily Run-About)
85 Celica GT-S (Summer Fun Car)
http://sleekaman.webs.com/
sleekaman is offline   Reply With Quote
Old 08-07-2004, 05:07 PM   #6 (permalink)
Sleeper-still sleeping
Redline's Avatar
View Redline's Photo Gallery
same here....it's my motor too. Maybe I should check out the linkages too. Can somebody point me to their location?
2003 4WD XR Matrix
Mods: HID low-beams, Injen CAI, Pioneer mp3 H/U, Tein SS Coilovers, Hella foglights, Corolla TRD STB, TRD 17" alloys w/ General Exclaim UHP, stubby antenna, KVR cross-drilled rotors, 35% tint all-around.
Pending: DIY-fix for front lip kit...
Redline is offline   Reply With Quote
Old 12-12-2007, 09:32 AM   #7 (permalink)
View petermiddleton's Photo Gallery
now how to seperate motor and linkage?
tryint to replace a wiper motor on a 95 camry wagon my haynes manual just says to pry with a screwdriver I assume they mean to pop the ball and socket joint apart? can the nut on the motor be removed and then the eccentric arm swapped to a good motor?
petermiddleton is offline   Reply With Quote
