my wife's camry has an intermittent problem with starting recently
i jump-started it
the battery was replaced - the part guy tested it, told me it was on its last leg
however, it happened again this morning
i was able to get it started by jiggling the shifter
i suspect it is the neutral safety switch that is intermittent
in the course of trying to locate the switch, i have gone to the local library; they did not have the haynes manual, the local auto part stores, none for 97 camry, the local book stores, none
could someone point out the switch location, and let me know if it could be repaired/adjusted, as i read that it is absurbdly expensive to have it replaced
TIA,
toyownner
