Loose ground wire search 1989 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-04-2004, 11:26 PM   #1 (permalink)
View gipper89's Photo Gallery
Hi, My wipers, pwr windows, blower fan etc. are going nuts!
Fuses keep blowing and the tail lights are out too. I think I have a loose ground wire somewhere but don't know where to begin to look. Has anybody out there had to check their grounds? I sure could use some help.
Thanks, Tiffany
gipper89 is offline   Reply With Quote
Old 12-05-2004, 10:09 AM   #2 (permalink)
Banned
View Talisman's Photo Gallery
Thanks, Tiffany
Well seeing as a girl posted this and we they are pretty rare here on TN, I am giving this a free bump. Unfortunately I can't help you with your problem though.
Talisman is offline   Reply With Quote
Old 12-05-2004, 01:43 PM   #3 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Fuses that blow are due to too much current being drawn (which fuses blow?)
I have read that there are some issues with the bundle of wires that moves when the trunk is open and closed, May want to check those.
Probably need more information.
CraigW is offline   Reply With Quote
Old 12-05-2004, 02:27 PM   #4 (permalink)
Turn that shit up!
McTimson's Avatar
View McTimson's Photo Gallery
I would start by checking right from the battery - first clean the contacts on the battery, and make sure it's firmly connected, then clean the wire that connects it to the frame of the car, and secure that firmly as well.
McTimson is offline   Reply With Quote
Old 12-05-2004, 06:43 PM   #5 (permalink)
CraigW, the fuses are pwr windows, wipers, seat belt, blower fan.
My brake lights are out too. Could residue on the battery terminal be the culprit?
I'm gonna check first thing in the morning anyway.
Thanks for your help, Tiffany
Old 12-05-2004, 07:15 PM   #6 (permalink)
Do the bulbs (that still work) seem super bright ?? How long do the fuses last.
Old 12-06-2004, 09:37 AM   #7 (permalink)
The brake lights don't work at all! The bulbs are good I can see the filaments and the fuse is good, never blown.
There was a little crud on the negative batt terminal which I cleaned with a wire brush and both grounds are intact.
I inspected the wire bundles in the trunk as much as I could and they look pristine.
I'm not sure where else to check. ANY ideas?! I'm going crazy!
Thank you for your help!
Old 12-06-2004, 11:26 AM   #8 (permalink)
For the brake lamps, Only thing left if you checked those items would be the brake switch itself. Located on the drivers side, operated by the brake pedal.
Do you have a voltmeter or test lamp ?? Do you know any good Electrical Engineers ?
