94 v6le ABS and brake trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2004, 07:08 AM   #1 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i think i have a major problem with my brake on my 94 v6le,
the symptom is, when i step on the brake, sometime the vehicle doesn't stop, normally only happen when i initially reverse or drive from the parking lot, and a few time i have to quickly shift nob to P to stop the car to avoid a collision.
when i step on the brake pedal, it does go down, but just not stopping the car, and if i shift to P and pump the brake pedal a few time, then the brake seems to be functional, and will continue to function until next time i shut off the engine overnite. the symtom seems worse at colder weather.
the brake master cylinder has been changed, the brake fluid is bleeded and topped.
also my ABS light is on after i made a u turn and heard some noise, and has been on since then.
would any one point out what are the possible causes? ABS module,
bronzemaxell is offline   Reply With Quote
