P0330 / not replacing knock sensor - Toyota Nation Forum : Toyota Car and Truck Forums
3rd & 4th Generation (19921996 & 19972001) Toyota Camry Discussion for years: 1992-1996 & 1997-2001 Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 23 Old 10-05-2013, 12:06 PM Thread Starter
Quoted: 13 Post(s)
(Thread Starter)
Hey
I been reading through the forums and before I go ahead and attempt the replacement of my knock sensors, I am not sure if this will make sense but has anybody had this error code and did not have to replace their knock sensors to fix this?
2001 Solara V6 imz-fe
i found this which is absolutely golden Diagnosing and replacing knock sensors on the 3VZ-FE V6
SoHitD is offline
post #2 of 23 Old 10-05-2013, 12:08 PM Thread Starter
Quoted: 13 Post(s)
(Thread Starter)
i dont hear any knocking or pinging, but I do experience a small power loss/lack of acceleration,
and gas mileages seems normal/steady
SoHitD is offline
post #3 of 23 Old 10-06-2013, 01:55 AM
抵抗は無駄です
fenixus's Avatar
Quoted: 7 Post(s)
I think that knock sensors can detect inaudible to human ear knocks (pre-ignition detonation), you won't hear that, you will just feel effects of it when ECU reacts to those and retards timing or goes into a limp-mode.
the code P0330 means that ECU commenced a maximum timing retardation to prevent any possible damage to engine, because it lost signal from knock sensor. this behavior gets returned to normal with ignition switched off, so you don't even need to reset the ECU probably.
P0330 = Knock Sensor 2 Circuit Malfunction
DTC detection condition:
No knock sensor 2 signal to ECM with engine speed between 2,000 rpm and 5,600 rpm.
Trouble area:
-Open or short in knock sensor 2 circuit
-Knock sensor 2 (looseness)
-ECM
gas mileage usually goes down when this happens a lot and ECU falls into a limp mode because of it every time (until you cycle ignition).
apart from bad sensor, it could very well be a problem with wiring to the front bank's knock sensor. have you checked the plug already, maybe it's just loose?
'02 Solara SLE V6 1MZ-FE/A541E@ 149k
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
items For Sale
fenixus is offline
post #4 of 23 Old 10-06-2013, 08:24 AM
ASE CMAT L1 MRRT
Quoted: 56 Post(s)
You should replace both knock sensors and also the wiring harness to the knock sensors. Murphy's law states that if one of the two knock sensors is bad and you only replace the one, then the other will go bad in a week. Seriously, the other one is just as old and could fail at any time
These knock sensors are critical, so they should be replaced when a fault code for their failure sets.
Mine : 2009 Avalon XL Magnetic Gray Metallic
Hers : 2010 RAV4 Base 2.5 AWD Pacific Blue Metallic
If I have helped, please hit the thanks button.
FixItt is offline
post #5 of 23 Old 10-06-2013, 09:33 AM
Chris Crash's Avatar
Quoted: 30 Post(s)
iTrader Score: 13 reviews
These knock sensors are super sensitive, but usually don't go bad. They're also super expensive.
You have either a bad wiring harness or a bad knock sensor, there is no CEL if it determines a knock. Start by checking the sensor for tightness. You'd need an oscilloscope to test it's function, though. You can test the wire/connector.
I would replace the sensor. You'll need the Denso sensor as the other, in my experience, do not work. I got mine from Carquest for $190.
2016 Toyota Corolla S Plus 6-speed
2015 Dodge Ram 1500
1997 Toyota Camry LE 5-speed
1994 Toyota Camry J-Vin
1997 Toyota Camry CE 5-speed
Chris Crash is offline
post #6 of 23 Old 10-06-2013, 03:38 PM
Quoted: 0 Post(s)
I just finished rebuilding a 1mz a month ago, within startup, both knock sensors were gone. Replaced them and wiring harness and no code since then. Its a pita to replace but not impossible
Goodluck
Charley
charley240sx is offline
post #7 of 23 Old 10-06-2013, 03:47 PM
ASE CMAT L1 MRRT
Quoted: 56 Post(s)
I have a whole box of faulty knock sensors that tells otherwise. I've replaced them on Chevy, Cadillac, Nissan, Infiniti, Toyota.
Especially Nissan/Infiniti 3.0V6 like in the Maxima and I30 They even give you the connector and pigtail, since the connection on these must be clean and tight. My big mitts can barely reach under the intake manifold to get to the knock sensor on these, but if I have to replace one in a Pathfinder or other vehicle where the engine is not transverse, then major disassembly is in order.
Oh, DENSO only please.
FixItt is offline
post #8 of 23 Old 10-06-2013, 06:03 PM Thread Starter
Quoted: 13 Post(s)
(Thread Starter)
thanks guys appreciate it, yeah I'm going to have a nice big job ahead of me, I have some engine leaks im going to try and fix too, by replacing the rear valve cover gaskets,
and yep thats what I been told too replace both knock sensors,
am I able to check the wire tightness before I start operation or I have to remove the manifold for that?
SoHitD is offline
post #9 of 23 Old 10-06-2013, 10:15 PM
BMR
Deputy of Mayberry
BMR's Avatar
Quoted: 557 Post(s)
If you're asking about the connections at the knock sensors, no, there's no way to get a hand in there to check without removing the intake plenum and intake manifold.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 25k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 346k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is online now
The Following User Says Thank You to BMR For This Useful Post:
SoHitD (10-07-2013)
post #10 of 23 Old 10-06-2013, 10:32 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 7 Post(s)
is this sensor located in the same spot on 1mz-fe as it is on 3vz-fe?
items For Sale
fenixus is offline
post #11 of 23 Old 10-07-2013, 12:02 AM
BMR
Deputy of Mayberry
BMR's Avatar
Quoted: 557 Post(s)
Yep. And there are two knock sensors, one mounted on each bank. You can see one of 'em in this pic, left of the coolant bypass hose. The other is blocked from view by the hose.
BMR is online now
fenixus (10-07-2013)
post #12 of 23 Old 10-07-2013, 08:34 AM Thread Starter
Quoted: 13 Post(s)
(Thread Starter)
yeah, thanks guys I appreciate it, the day i decide to operate is def going to be a fun a day , but at least i'll be saving money assuming I don't screw anything up or forget to screw anything :P, seems pretty straight forward though
SoHitD is offline
post #13 of 23 Old 06-14-2014, 12:35 PM
Senior TN Member
Quoted: 7 Post(s)
Trouble area:
-ECM
My 2001 Toyota Avalon just glow the check engine light 2 days ago. It's the P0330 code for bank 2 knock sensor. Where is the front bank's knock sensor wire at and what color? I erased the code to see if it would come back, it haven't.
aznstylez is offline
post #14 of 23 Old 06-14-2014, 12:52 PM Thread Starter
Quoted: 13 Post(s)
(Thread Starter)
what engine do you have? I believe they are white wires, google the ECU wiring diagram for your car
I still have not replaced my knock or spliced the wires, driving with a check engine line for past 6-7 months or so, and its killin my fuel economy
SoHitD is offline
post #15 of 23 Old 06-14-2014, 02:14 PM
Senior TN Member
Quoted: 7 Post(s)
I have the 1MZ-FE with VVT-I engine. It has over 280,000 miles already. It's not making any knocking sound or any sound at all. My dad's 1999 Avalon with over 475,000 miles haven't have this sort of problem yet.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > 3rd & 4th Generation (19921996 & 19972001)
User Tag List
Linear Mode Linear Mode
Back
