2001 5sfe Turbo Camry Project Help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2005, 10:53 PM   #1 (permalink)
View speedpro81's Photo Gallery
I am trying to turbo my camry using mostly mr2 turbo parts, the only thing I am confused about is how to hook up the oil line, I was told to get a 3sfe turbo oil pan so I got that, but where do you hook up the other oil line? The mr2 oil pipe end/connector lines up with a blank cap on my block of the camry engine. I assume there is som kind of assembly or fitting that I may need to get or at least another place to tap into for the oil. Please help if yu have any advice on this.
my turbo setup came from a '93 MR2 turbo (manifold, turbo,pipes, etc) and the intercooler came from my Saab 900 Convertible, a HKS BOV and a 3sfe map sensor and injectors.
01 Camry 5SFE Turbo
speedpro81 is offline   Reply With Quote
Old 01-13-2005, 11:11 PM   #2 (permalink)
Motorcyle Tech
Racer_Rodney's Avatar
View Racer_Rodney's Photo Gallery
Keep me posted on this man I will be right behind you if you are sucessful,
Good luck
CarDomain pics-->http://members.cardomain.com/racer_rodney
My WebSite------>http://rcarman.home.mchsi.com/
Racer_Rodney is offline   Reply With Quote
Old 01-13-2005, 11:28 PM   #3 (permalink)
Good luck
I will keep you informed, I noticed you have the same Lighted Gauge inserts as I do, have you had any trouble with yours splitting apart around the edges or gettings raised places where the screw holes are, the set I have is doing that, I have had mine for a while and they slowy started to do that, especially on hot days!
01 Camry 5SFE Turbo
Old 01-14-2005, 12:24 AM   #4 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
General procedure I believe is to use a T fitting at the oil pressure sensor and source your oil from that. T fitting goes into block, one side goes to sensor, one goes to CT26 (I assume) feed line. The return line then comes from the CT26 to the 3SGTE oil pan. Or you could tap the stock pan if you are short on cash just make sure the oil return point is tapped above the oil level in the pan so it can drain properly. Then you generally tap coolant lines from the lines under the throttle body that prevent icing in cold conditions I believe.
97camryman is offline   Reply With Quote
Old 01-14-2005, 12:27 AM   #5 (permalink)
Motorcyle Tech
nope, no probs yet...
when I put them in there was light comming in around the gauge but I fixed it
Old 01-14-2005, 03:16 PM   #6 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
There is no 3s-fe turbo (from the factory, at least). You need a 3s-gte oil pan.
There is also no 3s-fe MAP sensor (not counting the late 3s-fe from the Rav4, but you don't want to use that one). I hope you mean 3s-gte map sensor. 3s-fe injector are worthless to you, as are 3s-gte injectors (they are the wrong impedance). I believe you want non-turbo Supra injectors.
Coolant lines to the turbo are for cooling, not to prevent icing.
Good luck!
-Charlie
Old 01-14-2005, 03:22 PM   #7 (permalink)
Guess whos back
View CamryWhat?'s Photo Gallery
Ya it heard its easier just to tap your own pan... i can tap a pan and make flanges fore ya....PM me if you are intrested
And if you have a question about your turbo set-up PM too.. i will be glad to help i am about 80% done(need to find mr2 mapsensor and manifold)
Nick
2000 VW Golf: CAI Exhaust 18's Koni/Nuespeed
92 Camry- No motor Stock and Stock!
CamryWhat? is offline   Reply With Quote
Old 01-14-2005, 04:02 PM   #8 (permalink)
97camryman's Avatar
-Charlie
Correct but the lines to the throttle body are there to keep the throttle body from icing up in cold weather. Coolant is circulated through passages in the throttle body to warm it. You can route the engine coolant to go through the throttle body and then the turbo and then return to the block.
Old 01-15-2005, 12:48 PM   #9 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
Keep me informed as well, I'm in the process of gathering part for turbo.
Good Luck
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
S2B_Blown_3.5 is offline   Reply With Quote
Old 01-15-2005, 01:21 PM   #10 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
3S-GTE injectors are also side feed. 5S-FE is top feed.
Injectors from a 2JZ-GE.
"Skoolin' the unlearned!"
Old 01-16-2005, 03:44 AM   #11 (permalink)
I meant to put 3SGTE for the map sensor and the injects are my stock ones for my first post, I didn't pay notice I had it wrong, I found a threaded screw cap on my block that had very good oil pressure behind it today and I hooked my supply line to it and I tapped a fitting in the oil pan for the return, I hooked my coolant lines up and all the piping and fired it up, I used a manual boost controller and set the boost to 6 psi with a gauge, it had great reponse at around 2000+ rpms, it was running a tad bit lean when I turned it up to 8 psiso i backed it down to 6 again. I'll be heading to the muffler shop monday to get my ehaust pipes re-welded. The O2 housings from the MR2's do not fit unless they are cut down below the bottom of the turbo with a pipe going out sideways, the housing would not clear my motor mount nor would the bulking CAT. assembly which I did away with. Has anyone ever hooked up a AFC to a Camry before? Does it make a difference? Thanks for all you Ideas
01 Camry 5SFE Turbo
Old 01-16-2005, 03:53 AM   #12 (permalink)
Is there any performance chips avaliable for Camrys that work? or upgraded ECU's?
01 Camry 5SFE Turbo
Old 01-16-2005, 09:49 AM   #13 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
you can go piggy back or go to Tech Tom and have them re-flash your e-prom...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 01-16-2005, 01:18 PM   #14 (permalink)
View anuthaCamry's Photo Gallery
what's the comp ratio of the engine? critically important for turbocharging - they are always less than stock engine except for really high performance engines.
The ecu on a turbo car should do two competing things: spark advance with increases in rpm, and spark retard with increases in boost. Msd ignition makes such a device for supercharged (turbo) applications, and oh yeah use premium plus fuel octane additive. I hope that you are using a high-temp turbo hose for the coolant return on the top of the turbo (normal hoses will burst, which will crack mr. turbo) . Just some thoughts...
btw, turb
anuthaCamry is offline   Reply With Quote
Old 01-17-2005, 03:02 AM   #15 (permalink)
white90dx's Avatar
Correct. Coolant lines through the throttle body also aid in warming up the incoming air to the engine to the appropriate temperature for fuel atomization for emissions (but NOT power). Running coolant lines to the turbo from the throttle body is not a good idea - there is not enough flow.
-Charlie
