rod bearing - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 8 Old 11-04-2013, 01:25 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
rod bearing
I have a 2001 Toyota camry 2.2 im having problems with bering number one when I put it in I can move the rod side to side can some one help me plz im stuck I have cheked everthing I can think of
bobby32 is offline
post #2 of 8 Old 11-04-2013, 02:48 PM
Senior TN Member
Quoted: 3 Post(s)
You will need to find the specs on the allowable side play on the rod bearings.
Does the crank or rod look worn on the edges?
Do the other rods have play?
RonR is offline
post #3 of 8 Old 11-04-2013, 03:16 PM
Senior TN Member
dc_98_cam's Avatar
Quoted: 110 Post(s)
Is the excessive clearance only on the #1 connecting rod, or is it also on other connecting rods?
About how many miles do you have on that engine?
former owner 98 Camry LE, 2.2L, automatic
54k miles, drop in K&N A/F, ... timing belt, water pump, NSS
dc_98_cam is offline
post #4 of 8 Old 11-04-2013, 05:04 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
only on the number one connecting rod . all the outher ones are good no play
bobby32 is offline
post #5 of 8 Old 11-04-2013, 05:30 PM
Senior TN Member
dc_98_cam's Avatar
Quoted: 110 Post(s)
What I would want to know ... can you install a new connecting rod ... with piston and rings ... from the bottom?
You should be able to measure the thickness of the connecting rod ... where it is worn ... and compare this to the thickness of a new connecting rod.
If the wear is actually on the crankshaft, then you aren't going to have a simple repair.
... Just an idea ... I don't know if this would actually work though.
post #6 of 8 Old 11-04-2013, 05:36 PM
Senior TN Member
carsrus's Avatar
Quoted: 171 Post(s)
Nope. Crank has to come out that way.
carsrus is offline
post #7 of 8 Old 11-04-2013, 06:57 PM
Senior TN Member
Quoted: 2 Post(s)
You should NEVER remove a piston/rod from the bottom. Mainly because you would have to separate the engine and transmission to do it, and you would have to be REALLY creative in order to compress the piston rings to be able to be installed from the crank side of the engine.
CrystalMethod is offline
post #8 of 8 Old 11-04-2013, 10:38 PM
イリジウム
Quoted: 210 Post(s)
If the rod spun a bearing then you need to at least check the roundness and taper of that end before reusing it or it'll likely spin again. How's the rod journal? Even if you use a new rod you need to mic the journal.
I can't find the article about an in car re-ring and re-main on a Honda engine by pulling the pistons from the bottom. There was also damaged ring lands on one piston IIRC causing it to smoke like crazy. At least for that 4-cyl it's possible. Putting the piston back can be quite a challenge.
I'd change out the rod bolts too.
JohnGD is offline
User Tag List
Linear Mode Linear Mode
« Back
