92 camry power problem-please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2005, 09:35 PM   #1 (permalink)
View ashok patel's Photo Gallery
Smile 92 camry power problem-please help
hello, Can anyone help with my 92 camry power problem please.
1. it feels like lak of power on acceleration.
2. also running rough at idle speed and slight surging.
3. before engine was running at 2500rpm at 70mph and now it runs 2600rpm to go to 70mph.
4. when i start driving engine has to run higher rpm to shift from gears , feels like i have to push it to get it going.
5. no effect on pressing power on or off button. power on/off light does come on.
- replaced spark plugs, wires, distributor cap and rotor, fuel and air filter and pcv valve.
- not getting any engine check light.
please help.
thanks
ashok patel is offline   Reply With Quote
Old 01-18-2005, 10:24 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Check the timing and check for vacuum leaks.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 01-18-2005, 11:15 PM   #3 (permalink)
View anuthaCamry's Photo Gallery
tire pressure, engine/tran oil level/quality
anuthaCamry is offline   Reply With Quote
Old 01-18-2005, 11:19 PM   #4 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
Dump half a can of Seafoam in your gas tank when it nears empty, then fill it up.
Do a full tuneup: all fluids, all belts, sparkplugs, air filter.
edit: maybe i should read the whole post, eh?
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 01-19-2005, 07:50 AM   #5 (permalink)
thanks for the reply.
My engine oil level is ok. Transmission oil level is high- does it cause a problem?
Can't find any vacuum leak. Also did the tune up. Tire pressure is ok.
I have added Preston fuel injector cleaner in the gas tank for last two tank fill ups.
still no change.
Please help.
Thanks
Old 01-19-2005, 07:53 AM   #6 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $284080
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
The tranny fuid shouldn't be high, thatll make more work for the motor....hence the lack of power. Also, just a heads up, check the exhaust as well, just to make sure that there is not another culpri in this.
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 01-19-2005, 08:03 AM   #7 (permalink)
I am going for transmission fluid flush job that will bring the level to correct level.
The exhaust system is new from the manifold to the tail pipe except catalytic converter.
This car has 132000 miles.
Can fuel pressure regulator cause this problem?
I disconnected the vacuum pipe to the regulator and checked for diafram leak and it is ok.
please help.
thanks
Old 01-19-2005, 08:26 AM   #8 (permalink)
Knailgun's Avatar
please help.
thanks
Fuel pressure may have something to do with it, though I doubt it. My guess is the fluid level. The other thing I was thinking of, was bad gas??? maybe a longshot but ya never know.
Old 01-19-2005, 07:23 PM   #9 (permalink)
insufficient fuel pressure from a bad regulator = bad
clogged catylitic = bad
there are specific conditions on checking tran fluid, I believe it's engine running in park fluid warm after driving 10-20 miles. remove stick wipe. put stick all the way in, remove, inspect on 'hot' ignore the fact that there might be a 'cold' section
it would be a really good idea for YOU to find out exactly how to check the level on your specific car. trannies are killed by overfilling.
Old 01-19-2005, 08:19 PM   #10 (permalink)
Always Under Construction
View whocares04's Photo Gallery
i don't know what grade fuel (87, 89, 93) but maybe try 93? and how has your gas mileage been the last couple of tanks? again, maybe exhaust, it COULD possibly be an O2 sensor and u have a faulty check engine light?
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 01-19-2005, 08:24 PM   #11 (permalink)
Toysrme's Avatar
Cool
Forget 93.
3vz-fe's call for 87 and have no use for more stable gasoline hah!
Dumping a full can of seafoam in a near empty tank, then filling would definately solve that problem if it was just a random bad tank of gas.
Now with Turbo!
Old 01-19-2005, 10:45 PM   #12 (permalink)
engineer in training
Gameroom cash: $145055
if you are having problems when the engine is cold then you need to let it warm up before you drive, its really bad for an engine to be run up to 70 mph before it is warm and it will not drive right
