ECU location remote transmitter help rs3000 98 Camry le - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2005, 11:21 PM   #1 (permalink)
View WiseGuyMMIV's Photo Gallery
After searching the forum for help locating the ECU for the '98 camry le, I checked under the seats and under the driver's dash/steering column area. I don't see it. I know it has one, as the car used to have a working rs3000 remote. What I need is a pic of the ECU and it's location, if any of you happen to be working under your dash at the moment. I know that's a lot to ask. Please help if you can. I have instructions on how to program the remotes once I find the ECU.
Thanks.
WiseGuyMMIV is offline   Reply With Quote
Old 01-22-2005, 11:32 PM   #2 (permalink)
View anuthaCamry's Photo Gallery
behind/under the glove
anuthaCamry is offline   Reply With Quote
Old 01-23-2005, 08:31 AM   #3 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
The TSB AX005-99 "Toyota VIP RS3000 Programming" Shows it as located to the far left side of the dash, about mid level, below the left side vent.
BUT !!!! It also shows the location on my Corolla as under the seat AND I HAVE NOT FOUND IT YET !!!
Also, there should be another box which contains the potentiometer adjustment for the glass breakage sensitivity. (on my 00 Corolla it is under the center console)
If you want the TSB, PM with E-Mail and I will get it to you.
CraigW is offline   Reply With Quote
