Help me with correct belt size- underdrive crank pulley for 5SFE - Toyota Nation Forum : Toyota Car and Truck Forums
ป Wheel & Tire Center
Old 01-23-2005, 09:13 PM   #1 (permalink)
metamorphosis
cman2000's Avatar
View cman2000's Photo Gallery
Question Help me with correct belt size- underdrive crank pulley for 5SFE
I ordered the unorthodox underdrive crank pulley for my 5SFE camry last friday. I should get it early this week. I downloaded the instructions and am kinda confused as to which new belts I need.
I know my camry has 1 belt that drives both the alternator and A/C. here are what the instructions say:
New Belt Sizes (The belt sizes used may vary slightly. We recommend the use of Gates Brand belts, belt sizing varies slightly among belt manufacturers)
1. • Alternator and A/C Belt– Use Gates K050425 (43 1/8” or 1095MM), alternate belt size use Gates K050415 (42” or 1065MM)
2. • Alternator w/o A/C Belt – 2.0L Use Gates K050390 (39 5/8” or 1005MM) / 2.2L Use Gates K050380 (38.75” or 985MM)
3. • Power Steering Belt – Use Gates K030290 (29 5/8” or 750MM)
Since my is Alternator and A/C belt, I can skip #2. I went to autozone and got the Gates K050425 (43 1/8") and the power steering belt (K030290).
My question is, do I need both belts mentioned in #1 above? it seems rather confusing as to which belt I need from #1...both the K050425 and K050415 or just one of them? and if it's just one, which one?
If I need both belts in #1, then I have to go back and have autozone order the second one (K050415)..they don't have any in stock.
I'm getting the crank pulley installed this coming saturday so I would like to get the belts beforehand. any help would be great.
2005 Acura RSX Nighthawk Black Auto w/ Black Leather
2000 Camry LE - Damaged in a wreck (other driver's stupidity ) . being repairing as we speak...
cman2000 is offline   Reply With Quote
Old 01-23-2005, 09:33 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $992975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I have a set of unorthodox pulleys installed too. you just need one of those belts and the power steering belt. I don't know which one though. i would think the 1st one mentioned would be the prefered one. there's only a little over an inch difference between them.but it could be the difference between tight belt or not..The guys at unorthodox are pretty cool and helpful.i've bought a few things from them.maybe give them a call... http://members.cardomain.com/mr2bad
The Jedi Speeder at CarDomain
Old 01-23-2005, 09:38 PM   #3 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
I have the same pulley. I used the Gates K050425 (43 1/8” or 1095MM). The instructions tell you to use that or if you can't get that brand use Gates K050415 (42” or 1065MM)
Then you need a new power steering belt. I used Gates K030290 (29 5/8” or 750MM) You only need one belt from #1 it just gives you two options that will both work if you cannot get one of the belts. Since the belt tension is adjustable you can use either belt its just one is a tad bit longer than the other. A few tips: brace the breaker bar with socket against the ground with the car jacked up and just turn the key for a second to loosen the bolt holding the pulley in. Then carefully pull it off. Slide the new pulley on and brace the flywheel by removing the two bolts holding the starter in and pulling it out. Then stick a big flathead screwdriver in and jam it against the teeth. Have a friend tighten the bolt then. Make sure the power steering belt is good and tight! Mine slipped at first. Thats all there is to it!!
97camryman is offline   Reply With Quote
Old 01-23-2005, 09:46 PM   #4 (permalink)
metamorphosis
cman2000's Avatar
hey thanks MR2BAD and 97camryman for all the help. cool, then I have both the belts I need for the install. now I just need for the crank pulley to come in
btw, how have you 2 (or anyone else) liked the crank pulley? i've heard you do feel a bit of difference in performance...was it a little or alot? i guess i'll find out this week.
thanks again guys
Old 01-23-2005, 10:05 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I installed them on my'01 MR2 Spyder. it took several days of reg. and highway driving for the VVTi computer to adapt. but I could feel the difference then.more power gets to the ground and reving up a little quicker. I added an Unorthodox flywheel and windowed kevlar clutch to that and theres quite a bit of difference now.
Old 01-23-2005, 10:16 PM   #6 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
SO what does an 'Unorthodox' underdrive pulley do?
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 01-23-2005, 11:08 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Unorthodox Racing is the name of the company that makes the pulley(s). By reducing the weight of rotational mass at the crank, more power is delivered to the wheels.you don't make more power with that you just free it up to get it to the ground.your engine will rev up alot quicker too. it's also easier on your crankshaft not to have to spin all that weight.giving longer journal bearing life. it translates to approximately 2.7 hp/lb freed up to the wheels. my stock crank pulley weighed 3 lbs. the lightened pulley weighs 8 oz.! my stock flywheel weighed 15lbs, the lightened one weighs 8lbs. thats 10.5 lbs off my crank x2.7=28.35hp released to the ground. of course these figures are approx. but fairly close
Old 01-24-2005, 01:55 AM   #8 (permalink)
40x40 pixels is crap !
Velox_camry's Avatar
View Velox_camry's Photo Gallery
cant u just use the stock belts ? mine are only a few thousand miles old is it really nescessary to get them replaced ?
"Guardrails...those things that separate the men from the boys."-Fumiaki Komatsu
Velox_camry is offline   Reply With Quote
Old 01-24-2005, 06:06 AM   #9 (permalink)
metamorphosis
cman2000's Avatar
cool. I figured it would take 5-7 days of regular driving for the ECU to recalibrate w/ the crank pulley. it's all good...i drive like 1 hr to work everyday mostly freeway.
Old 01-24-2005, 06:08 AM   #10 (permalink)
metamorphosis
cman2000's Avatar
oops forgot to respond to your question. i think it is best to replace the belts. since the crank pulley is a different size than the OEM pulley, naturally you would think that new belts are needed too. it's pretty cheap...the A/C and alternator belt (1 belt) was $13.99 at autozone, and power steering belt was $5.99
Old 01-24-2005, 08:13 AM   #11 (permalink)
Boost Is On The Way
View ChewDogg's Photo Gallery
Don't these pulleys mess with the harmonic balancing of the car?
1995 Camry XLE
www.teamphatrides.com
ChewDogg is offline   Reply With Quote
Old 01-24-2005, 08:23 AM   #12 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
if you have one it can. but not all cranks have them. my Spyder does not...
Old 01-24-2005, 08:55 PM   #13 (permalink)
metamorphosis
cman2000's Avatar
^^ and i've talked w/ other camry owners and they haven;t had a problem w/ their crank pulleys. and they've enjoyed their added performance too in fact, blue meanie (a moderator here) has one and was helping me out earlier
Old 01-24-2005, 09:05 PM   #14 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
lightened pulley's and flywheels are a great and simple mod that reaps worthwhile, noticeable performance for the money.
