... There isn't anything to it. It sit's on a bracket that you can loosen a bolt on and lower it, taking off the tension. You get to it through the wheel well. (Take the wheel off, unbolt plastic cover)
If those belts are going(or have been) bad, more than likely the timing belt is too... Might wanna get someone to replace that for you.
AIM/Yahoo Toysrme257th
Now with Turbo!
