Starter Problems 92 Camry 4cyl - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2005, 09:15 AM   #1 (permalink)
edud NT laiciffO
View KILLACAMNY's Photo Gallery
I start the car ok. When I shut it off after driving, it wont start up again. It has to sit for a while, then when I get back to it and turn the key, it'll start up fine. I'm turning the key and nothing, all the start up lights go on, its just when I turn the key all the way to start the car, nothing happens. Should I replace starter?
http://members.cardomain.com/killacamny
KILLACAMNY is offline   Reply With Quote
Old 01-28-2005, 09:27 AM   #2 (permalink)
Flagrant Fouler
Diehonda's Avatar
View Diehonda's Photo Gallery
There is a sensor that tells the car that it is in park. If it wears out then the car may not start yet all the lights and radio still work. I say this because my 91 did the same thing and that is what the problem ended up being. I could move the shifter thru from park to drive and back and sometimes that would fix it. It ended up driving me crazy and I replaced it. It was in my console under the shifter. If you have an automatic. It was actually inexpensive to replace. If it is a manual then I would have the starter checked.
Nice ride in the sig though
Free Gen 2 Camry book for anyone coming through Louisville, KY
Diehonda is offline   Reply With Quote
Old 01-28-2005, 11:44 AM   #3 (permalink)
edud NT laiciffO
Thanks for the info. Actually, I tried switching from Park to Neutral and it acted the same way. But I'll check out the sensors to be safe.
Where do I locate the sensors??
Old 01-28-2005, 11:46 AM   #4 (permalink)
View Calvin327's Photo Gallery
Check ignition system, wires, plugs, cap, rotor and try cleaning out the throttle body as well. Its a minor problem, nothing big.
Calvin327 is offline   Reply With Quote
Old 01-28-2005, 11:46 AM   #5 (permalink)
View alex86's Photo Gallery
haha the same happened to me but the car wouldnt start until like 5-10minz later nd it was not a good start up. it was like stuttering hard and running hard. but its fine now just that its jerking if i let go of the gas at 50mph. i still cant figure it out.
I have been given a sickness from the doc... Obsessive Compulsive Camry Dissorder... certifiable
alex86 is offline   Reply With Quote
Old 01-28-2005, 01:43 PM   #6 (permalink)
edud NT laiciffO
Wires, plus, rotors, cap and distributor was replaced in early summer. I even cleaned out the throttle body in the summer when I put a new intake pipe in.
Old 01-28-2005, 02:58 PM   #7 (permalink)
View burchard's Photo Gallery
If it is a stall warm and you have to wait 5 min to restart, or if you letit idle and stalls, ther is a good chance that you have the Engine Coolant Temp sensor mulfunctioning and sending the wrong signal to the computer. Serach this site for ECT or coolant temp sensor..
burchard is offline   Reply With Quote
Old 01-28-2005, 10:48 PM   #8 (permalink)
View anuthaCamry's Photo Gallery
could be a loose battery cable..
anuthaCamry is offline   Reply With Quote
Old 01-30-2005, 10:01 PM   #9 (permalink)
edud NT laiciffO
Swapped out the starter, all is well
Old 01-31-2005, 01:19 AM   #10 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
I tend to feel a slight jerk when I let off the gas when on the freeway as well. I never noticed it before.. It's as if the overdrive is off and I'm going 50+, but the overdrive is actually on and exhibiting the same behavior. Eh I dunno..perhaps the car is just old. It was made 1/1995 so it's officially ten years old
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
