95 Camry 4 cylinder cold start problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2005, 08:23 AM   #1 (permalink)
View joea's Photo Gallery
95 Camry 4 cylinder has a cold start problem. On any cold start, it does not "fast idle". No matter what the temperature. On really cold days, like 0 F. It is very hard to start.
Has new plugs and wires, the coolant and air temp sensors test out fine.
ideas?
joea is offline   Reply With Quote
Old 01-31-2005, 08:40 AM   #2 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Try doing a search on here. That might help since there has been many threads about cars not starting.
http://www.xclusive.bz
Old 01-31-2005, 08:53 AM   #3 (permalink)
View burchard's Photo Gallery
Ther is a good chance that it is the Air intake valve (AIC). A solenoid that allows air to bypass the mainfold when you start the car. It gest dirty with carbon deposits. an easy test is to spray 3 secs of throthle body cleaner into the p port and start the car. The cleanner will get to the oppening of the AIC in the TB and lubricate/clean the valve. It will choke a bit but will start. repeat the procedure 4-5 times. There is a lot of info in this forum about this classy problem with high mileage camrys. good luck.
burchard is offline   Reply With Quote
Old 01-31-2005, 09:15 PM   #4 (permalink)
View dallison's Photo Gallery
could also be the cold start sensor
1989 camry ghetto sled
dallison is offline   Reply With Quote
Old 01-31-2005, 09:40 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
IAC (idle air control) sensor and/or ECT (engine coolant temp) sensor.
http://www.toyotanation.com/forum/t27066.html
"Skoolin' the unlearned!"
