Question about 18x8 rims for 1999 camry le 4cyl. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2005, 12:50 AM   #1 (permalink)
trdcamrygracia's Avatar
View trdcamrygracia's Photo Gallery
i just got a set 18" rims.....its 18x8 offset 42.....will it fit on my car(1999 camry le 4cyl.).....and i plan to used 225/40/18....will it rub...do i need to install any wheel spacer to make it fit ..thanks
07 BMW E60 530I JET BLACK
trdcamrygracia is offline   Reply With Quote
Old 02-11-2005, 02:48 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
let me see, you got a set of wheels, and instead of test fitting them, you come here and ask?!
they should fit.
terrastrife is offline   Reply With Quote
Old 02-11-2005, 03:48 AM   #3 (permalink)
Night Speed's Avatar
View Night Speed's Photo Gallery
did you plan to lower?
Night Speed is offline   Reply With Quote
Old 02-11-2005, 09:16 AM   #4 (permalink)
i have tein s-tech lower spring on my car.....
Old 02-11-2005, 12:49 PM   #5 (permalink)
EvIdEnCe's Avatar
View EvIdEnCe's Photo Gallery
yo man, i got 18x8s and 225/40s and the tread is too small for the wheels.....i think that if I went with 235s, which wouldve fit the wheel better, that i wouldve rubbed in the back of my maxima.......bottom line is, if the wheels fit, get 235/40/18 tires
Signature is in violation of signature rule #2 and #4.
http://www.toyotanation.com/forum/t20118.html
EvIdEnCe is offline   Reply With Quote
Old 02-12-2005, 11:40 PM   #6 (permalink)
Originally Posted by UfoZ
You will probably have some issues with rubbing in the rear. I know Yukio was rubbing like crazy with his Volks but I guess he did a little cutting in there and the problem was fixed. If you run 225s youll be fine all around, 235s might be pushing it.
so if im used 225s it will be fine right
Old 02-13-2005, 12:21 AM   #7 (permalink)
Mitsubishi Diamante Owner
CDub LXi's Avatar
View CDub LXi's Photo Gallery
225 is what people are recommending for 18*7.5. If you put that tire on the 18*8 then the tire won't really look right on the rim. It'll look like it's folding over too much. If the company you're buying them from says it'll fit.. get them. But make sure they will take them back if they don't.
CDub LXi is offline   Reply With Quote
