Short Shifter for Gen 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2005, 01:47 AM   #1 (permalink)
View htang4's Photo Gallery
Does TRD or some other company sell a short shifter for the GEN 3 Camry?
My Camry SE shift feels so much like my 90 All Trac Turbo I once had. I was able to custom modify it through forums about Celicas.
I can't seem to find anything on TN about short shifters for my GEN 3 Camry.
Please help! I would love to have short shifts like a MR2 Turbo or those Hondas/Acuras.
Thanks,
Harry
93 Camry SE V6
htang4 is offline   Reply With Quote
Old 02-19-2005, 12:30 PM   #2 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
You could just cut the handle down and have a shortershifter, but that doesn't reduce the length of the throws. That may even give you a harder time shifting. However, I remember reading on this very forum that with some slight modifications the gen4 TRD unit can be massaged to fit and work. Check it out with a search... it was a while back
Steve
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 02-19-2005, 02:32 PM   #3 (permalink)
REAPER STRAIN's Avatar
View REAPER STRAIN's Photo Gallery
When I used the search button not too long about I read that the corolla short shifter (or was it a gen 4 short shifter?) would be used. All that is needed is to cut away small sections of the corners. Someone posted a DIY with really sweet pictures and all. If I find it I'll foward the link.
REAPER STRAIN is offline   Reply With Quote
Old 02-19-2005, 05:13 PM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
yeah corolla one can be haked to fit, or you can just add/remove metal on the stock one.
terrastrife is offline   Reply With Quote
Old 02-19-2005, 05:57 PM   #5 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
don't know about the v6, but I should imagine that a similar yeared celica short-shifter trick or kit would work just the same. AFAIK, celicas used the same tranny as the camry's in their 5S-FE parts.
and yeah, I noticed that you have a 3VZ, just sayin' though.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
