01 Camry, heated seats not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2005, 06:24 PM   #1 (permalink)
View monty2's Photo Gallery
4th Generation 01 Camry, heated seats not working
Have a Gen 4 camry with 95k and both heated seats just stopped working. I checked the fuse in the instument panel and it is fine. I looked under the seat to see if anything was disconnected but all looked to be okay. Any thoughts of how it could just stop all at once? I went to the dealer and as always, very costly just to run a diagnostic let alone fix the problem.
Your help is much appreciated.
Monty2
monty2 is offline   Reply With Quote
Old 02-25-2005, 05:11 PM   #2 (permalink)
That One Guy...
View Corollacrazy42's Photo Gallery
u have heated seats?! whats wrong with my 2001 cam.. ?
Corollacrazy42 is offline   Reply With Quote
Old 02-25-2005, 05:39 PM   #3 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
man, i have no clue..but props to you for having those, i wanted those on my gen 4 and was told this wan't even an option in 97
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 02-26-2005, 05:52 PM   #4 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
thats cause he has a gen 4.5
SnakeyeS is offline   Reply With Quote
Old 02-27-2005, 03:19 AM   #5 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
Is that just in Camrys in Canada? Because I don't think they were available in the U.S. even in 2000-01. I don't even know where they'd put the switches, because there's no holes or dummy plate in the center console or shifter trim for them.
Were these factory heated seats? Or did the dealer add them, perhaps from an aftermarket company?
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 02-27-2005, 10:42 AM   #6 (permalink)
These are factory installed heated seats. Not sure if they were available only in Canada. This is a Gen 4.5.. Called Toyota, they said these things usually go.. and it is EXPENSIVE to fix....
Old 02-27-2005, 10:47 AM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
awe
Old 02-27-2005, 12:50 PM   #8 (permalink)
View karazy's Photo Gallery
I don't know much about how they're set up, but I wouldn't think both seats would go out at the same time. Check to make sure there are no relays or fuses that you may have missed. You can do a continuity check on the seats if you can't find anything else.
karazy is offline   Reply With Quote
Old 03-03-2008, 03:43 PM   #9 (permalink)
View theoilman's Photo Gallery
Canada same problem
First post - sorry if I screw up. I have a 2001 XLE and had exactally the same thing happen to me. I bought the car new and treated it well but both heated seats stopped working just after the bumper to bumper warrenty ran out. The dealer said that both elements were burned out. I decided that if both burned out in just over three years then I wasn't spending $1000- to replace them for another three years. Canadian winters are cold but that's crazy.
theoilman is offline   Reply With Quote
