01 Camry o2 sensor behind CAT. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2005, 11:26 PM   #1 (permalink)
View speedpro81's Photo Gallery
What is the purpose of the o2 sensor behind the CAT on a 01 camry 4cyl. I have a exhaust cut out valve welded up after the first o2 sensor and I was wondering if there would be any performance issues when the o2 sensor behind the CAT does not see any exhaust when the exhaust is being bypassed, My Camry is turbo by the way and that was the reason for installing the cut-out valve. Any tips would be great
01 Camry 5SFE Turbo
speedpro81 is offline   Reply With Quote
Old 03-10-2005, 06:30 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
it's there for the OBDII, basicaly it checks to make sure the cat is working right.
think you will be fine because it sposta have a lower oxygen count after the cat so no o2 would make it not throw a cel, or it was in the inverse and your going to throw a cel everytime you use the bypass.
^ and leaving it that way!
Old 03-10-2005, 06:38 AM   #3 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
The purpose of the downstream O2 sensor (the one behind the Cat.) is to monitor the condition of the Cat. The catalytic converter uses up oxygen when working properly, so the computer compares the two O2 sensor readings. The downstream sensor should show almost no voltage when compared to the upstream. The upstream sensor will effect preformance, the downstream sensor will not.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 03-10-2005, 09:13 PM   #4 (permalink)
One other question, where is the Fuel pressure regulator and how could I up the fuel pressure? I thought the regulator was on the fuel rail with a vacuum line attached. Does trying to trick the computer by making the air intake sensor read a lower temperature reading help with anything performance wise?
I am looking for and trcks or tips on making more power.
01 Camry 5SFE Turbo
Old 03-12-2005, 11:32 AM   #5 (permalink)
01 Camry 5SFE Turbo
Old 03-12-2005, 12:24 PM   #6 (permalink)
ShawnM's Avatar
If I remember right the fuel pressure regulator is part of the fuel pump assemble in the tank on your car. There really isnt much you can do with it. Preformance wise, dumping more fuel in isnt gonna make much of a difference unless you get more air in as well. The computers job is to keep everything within certain limits for the best preformance and emissions. Trying to fool it will most likely turn on the check engin light or cause other problems.
--Shawn
03 Camry LE
67 Mustang
