Originally Posted by 95camguy
97's tend to have problems in the front suspension. im not sure if the gen 4 v6 has the same suspension as the 4 but make sure you check that out.
if the car your gonna look at makes noise in the front act like your really worried about the cost and then knock $$$ off the price. then go buy a $15 haynes manual and fix it yourself.
I have 165,000km on 97 LE 4 cyl
Todate 1 round replacement shocks
1 timing belt replacement - due again -- be careful with this
No clutch problems (manual) no transmission problems
Still original muffler
Front suspenson problem was wear in sway bar bushings -- often diagnosed as something worse
Brakes have not been touched -- need to check in a few days -- mostly highway driving
The car is solid -- no rust -- but I am not exposed to much salt
LOUSY Headlights & marginal heater
Good Luck
