Any fluids will mix fine.
Chances are it's something simple like the kick-down cable slide around, or the fluid is slow/really old.
(I put trans-tune in my car too)
Draining the pan and replacing the fluid doesn't change the majority of it, so I would change the fluid in the pan, drive a few miles, come back home, drain it again and THEN add the transtune.
That way you get the majority of the bad fluid out.
AIM/Yahoo Toysrme257th
Now with Turbo!
